With 3 GB of the latest GDDR5 memory and 1792 stream processors, and support for DirectX 11.2, the architecture is built to play the games with perfectly smooth action even at higher resolutions such as 2560 x 1440. In fact its Ultra HD graphics processor can feed even the latest 4K displays with the HDMI interface. The R9 280 family represents a breakthrough in cost: performance.
HDMI
Support for Deep Color, 7.1 High Bitrate Audio, and 3D stereoscopic, ensuring the highest quality Blu-ray and video experience possible from your PC. -
DisplayPort
Doubling the effective bandwidth of previous DisplayPort implementations, DisplayPort now includes support for multi-stream, allowing you to drive up to four separate monitors from a single DisplayPort connector, stereoscopic 3D monitor support and adds support for high quality, lossless, 7.1 channel audio formats. -
Dual-Link DVI-D
Equipped with the most popular Dual Link DVI (Digital Visual Interface), this card is able to display ultra high resolutions of up to 2560 x 1600 at 60 Hz. -
Dual-Link DVI-I
Advanced GDDR5 memory technology
GDDR5 memory provides twice the bandwidth per pin of GDDR3 memory, delivering more speed and higher bandwidth. -
AMD Avivo HD
Watch the hottest Blu-ray movies or other HD content at full 1080p display resolution and beyond and enjoy a more feature rich experience with enhanced Unified Video Decoder (UVD). -
AMD CrossFireX Multi-GPU technology
Triple or Quadruple gaming power with AMD CrossFireX Multi-GPU technology. AMD CrossFireX technology supports up to four graphics cards to be used in a single system. -
AMD HD3D technology
Enjoy the most immersive experience possible with full support for high definition stereoscopic 3D, a technique that presents 2D images in a format that creates the illusion of three-dimensional depth when using compatible 3D displays/glasses/software. -
28 nm GCN (Graphic Core Next) architecture
The 28 nm GCN Architecture's more efficient process technology puts more transistors in less space, enabling a dramatic increase in processing power. -
PCI Express 3.0
PCI-Express 3.0 delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU, maximizing the performance from your GPU when paired with the latest platforms. -
AMD Eyefinity 2.0
The next generation of AMD Eyefinity technology is here, featuring support for stereo 3D, universal bezel compensation and brand display configurations. Face it: the best just got better: The enhancements for AMD Radeon HD7000 series include: stereo 3D-multi-display stereoscopic 3D support via DisplayPort 16K x 16K maximum display group resolution-output up to 268 megapixels per GPU. -
SAPPHIRE Dual-X Cooling technology
Famous for the exclusive cooling solutions like the award winning Vapor Chamber Cooling technology - Vapor-X, SAPPHIRE's reputation for innovative excellence continues to grow with the introduction of the dual-extractor technology - Dual-X. Dual-X is a highly efficient multi-heatpipe cooler with dual fans that provide quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load. -
DirectX 11.2
The tessellation performance on AMD Radeon R9 series is up to 2x faster than the previous generation, and Direct-compute performance is also faster to accelerate advanced post-processing, filtering, and anti-aliasing techniques. Direct X11 games has never looked this good. -
OpenGL 4.3
OpenGL 4.3 improves the GPU efficiency by improving the shader process operation and capturing GPU tessellated geometry. The process of modifying an arbitrary subset of compress texture is also simplified. The memory management in handling shaders is more efficient as well. -
Mantle
Properly enabled games will reach heights of performance by speaking the language of graphics core next architecture. -
Dolby TrueHD and DTSHD Master Audio support
Support for copy protected, high bandwidth, 7.1 channel surround sound over HDMI. Get a fully immersive, high definition audio experience with the latest Blu-ray movies. -
TriXX utility
TriXX helps users to get the optimum performance from compatible SAPPHIRE graphics cards in any application by allowing them to monitor, tune and save different settings of key parameters for the card. -
AMD PowerPlay with ZeroCore Power technology
AMD PowerPlay is a power management technology in response to the GPU loading; AMD PowerPlay automatically manages the power consumption. AMD ZeroCore Power technology allows your AMD Radeon GPU to consume virtually no power when in idle state. When used with AMD CrossFire technology, it shuts down additional GPUs when they're not in use. -
Cutting-edge Quad HD display support
The display resolution on AMD Radeon HD7000 series is quadrupled to the resolution of 4K x 2K (4096 x 2160) from the outputs of DisplayPort and HDMI. -
AMD PowerTune technology
AMD PowerTune technology is a breakthrough technology that sets an entirely direction for maximum performance at TDP. It allows the GPU to be designed with higher engine clock speeds which can be applied on the broad set of applications that have thermal headroom. In HD 7900 series, AMD PowerTune technology enables intelligent power monitoring to enable higher clock speeds and better performance in your favorite games.
- Sapphire RADEON R9 280 Dual-X with Boost - graphics card - Radeon R9 280 - 3 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R9 280
- Memory
- 3 GB GDDR5
- Core Clock
- 850 MHz
- Boost Clock
- 940 MHz
- Stream Processors
- 1792
- Effective Memory Clock
- 5 GHz
- Memory Interface
- 384-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
- Max Monitors Supported
- 3
- Interfaces Details
- DVI-I (dual link) , HDMI , DVI-D (dual link) , DisplayPort
- API Supported
- OpenGL 4.3, DirectX 11.2, Mantle
- 3.4 cm x 26.2 cm x 11.2 cm
- Package Type
- Lite retail
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon R9 280
- Core Clock
- 850 MHz
- Boost Clock
- 940 MHz
- Stream Processors
- 1792
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 3
- API Supported
- Dual Slot Fan Cooler, High dynamic-range (HDR) rendering, Avivo HD Technology, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD App Acceleration, Deep Color technology, Dolby True HD support, DTS-HD Master Audio support, AMD Eyefinity Technology 2.0, Dual-X cooler, Graphics Core Next (GCN), AMD ZeroCore Power technology, 24x Custom Filter Anti-Aliasing (CFAA), AMD Unified Video Decoder (UVD), UEFI BIOS
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5 GHz
- Bus Width
- 384-bit
- Min RAM Size
- 4 GB
- Required Power Supply
- 500 W
- Additional Requirements
- CD-ROM, 2 x 6 pin PCI Express power connector
- Included Accessories
- 2 x 4 pin to 6 pin power cables
- Cables Included
- 1 x CrossFire cable
- Software Included
- Drivers & Utilities, Sapphire TriXX, AMD Catalyst Control Center
- 3.4 cm
- 26.2 cm
- 11.2 cm
- Package Details
- Lite retail
