Sanus VuePoint Tilting Wall Mount - 47"-80" TVs
Quicklinx: FW2GWS00 Mfr#: F58c2-B2
Type: Mounting kit
13 In Stock
£37.49 ex VAT
£44.98 inc VAT
The SANUS VuePoint F58c is an unparalleled wall mount solution for most 47" - 80" flat panel TVs up to 130 lbs. This mount features an exclusive tilting technology for effortless adjustment of viewing angles, helping to reduce glare with up to 15ยบ of tilt without the use of tools. Its low-profile design places the TV just 2" from the wall for a clean, flush appearance. Laterally adjustable TV brackets allow the mount to shift left and right on the wall plate for perfect placement, even with off-center wall studs. A quick latching mechanism holds the TV securely on the wall, and solid construction provides strength and durability.
Sanus VuePoint mounting kit - for flat panel
Mounting kit
Mounting Components
Tilt wall mount
Tilt
15°
Recommended Use
Flat panel
Recommended Display Size
47"-80"
VESA Mounting Interface
Up to 800 x 600 mm
Max Load Weight
59 kg
AV Furniture
Mounting kit
Mounting Components
Tilt wall mount
Recommended Use
Flat panel
Up to 800 x 600 mm
47"-80"
Tilt
15°
Max Load Weight
59 kg
Resources
The following resources are available for the Sanus VuePoint Tilting Wall Mount - 47"-80" TVs
Type: Mounting kit
Brand: Sanus
