Low-profile fixed wall mount solution for most 47–80" flat-panel TVs. Design places the TV just over 1" from the wall. Angled slots and integrated level make levelling and installation quick and easy. Lateral shift allows TV to slide left and right for perfect TV placement, even with off-center studs. Safety latch secures the TV to the wall for added safety.
For 47-80" Screens
Maximum Supporting Weight 61kg
With Locking Mechanism
Aluminium & Steel Construction
For Internal Use
Close-to-Wall Positioning
- Sanus SimplySafe VLL61-B2 mounting kit - for TV
- Product Type
- Mounting kit
- Mounting Components
- Fixed wall mount
- Recommended Use
- TV
- Recommended Display Size
- 47"-80"
AV Furniture
- Mounting kit
- Fixed wall mount
- Recommended Use
- TV
- 47"-80"
