SanDisk Cruzer Glide - USB flash drive - 64 GB - USB 2.0
Quicklinx: 89VLWS00 Mfr#: SDCZ60-064G-B35
Have you ever experienced storage as reliable and secure as this?
The Cruzer Glide USB Flash Drive offers an easy and secure way to share, move, and back up your most important files. Featuring a compact design with a retractable USB connector, this flash drive is ideal for data users who need easy, portable access to their media and personal files.
  • Lightweight, compact, portable design
  • 64GB Capacity to accommodate your most important data
  • Password-protect files with SanDisk SecureAccess software
  • Includes 2GB of cloud storage offered by YuuWaa™
  • Retractable USB connector
Lightweight Design with Retractable USB Connector
The Cruzer Glide USB flash drive has a sleek, streamlined design with an attractive black and red color scheme. Its compact size means it can easily slip into a front pocket or purse. The USB drive's connector retracts with a pull of the slide, protecting the drive when it's not in use.
High-Capacity Drive Stores Your Essential Files
Huge 64GB Capacity, the Cruzer Glide USB Flash Drive lets you carry your favorite media with you. You'll be able to store, share, and transport hours of HD video, entire photo albums, your music library and important documents.
Fast Drag-and-Drop File Transfer
To transfer files to your drive, plug the flash drive into your computer's USB port and drag the desired files into the drive's folder. No additional software or drivers are required, so you can begin transferring and backing up your files immediately.
SanDisk SecureAccess Software Protects Files with a Password and Encryption
Each Cruzer Glide USB flash drive is preloaded SanDisk SecureAccess which lets you create a password-protected folder for your sensitive files. The password protection uses 128-bit AES encryption, so you'll be able to share your drive without sharing private documents.
Includes 2GB of Cloud Storage
The Cruzer Glide USB flash drive also comes with 2GB of free online storage space provided by YuuWaa. This convenient cloud storage service features a drag-and-drop interface, so you can transfer your files to a secure YuuWaa server with just a few mouse clicks.
Durable and Temperature Proof
The Cruzer Glide USBFlash Drive can function in a variety of climates. It can operate in temperatures ranging from -13 to 185 degrees Fahrenheit, which means you'll be able to transfer files no matter where you are.
Warranty
The Cruzer Glide USB Flash Drive is backed by a two-year limited warranty.
Trust in SanDisk
All SanDisk products are constructed to the highest standards and rigorously tested at every stage of production, so you can be confident in the outstanding quality, performance and reliability of every SanDisk product.
Store your world in ours.
  • The capacity you need to store more
    Even with Full HD video and high resolution images hungry for storage space, 64GB Cruzer Glide USB Flash Drives give you plenty of headroom, just in case. If you need a heavy duty USB Flash Drive that can carry round tens of thousands of photos, tracks or videos – even Full HD video and multi-megapixel shots – then this is the perfect one for you.
  • Stylish performance
    64GB Cruzer Glide USB Flash Drives come in a simple, attractive and smooth red-and-black finish and feature a smart red slider that reveals or hides the USB connector at the push of a thumb, protecting it from accidental damage.
  • Check out the action
    The 64GB Cruzer Glide USB Flash Drive uses a glowing, amber-coloured LED to let you know that the drive is ready for reading or writing data. Once the Flash Drive is inserted into the USB port, the LED pulses when your files are being transferred and slows down when the drive is idle, keeping you up to date on what's happening.
  • Stay protected with SanDisk
    SanDisk SecureAccess software makes it easy to protect personal or business-critical files. Simply drag and drop files into the vault and they'll be protected by a personal password and automatic 128-bit AES encryption. This means that your content will stay private and secure when you take the drive out and about, or if you store it away for safekeeping.
  • Compatibility
    The Cruzer Glide Flash Drive is optimised for laptops and devices with USB 2.0 ports.
  • Reassurance with performance
    SanDisk develops and engineers its USB Flash Drives to maximise reliability, so you can count on your 64GB Cruzer Glide USB Flash Drive to store your important filesYou can enjoy yourself or work away with total peace of mind. Cruzer Glide USB Flash Drives are backed by a five-year limited warranty.
USB flash drive
Interface Type
USB 2.0
Storage Capacity
64 GB
Encryption Algorithm
128-bit AES
Middle East, Africa, Europe
Software Included
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
USB flash drive
Storage Capacity
64 GB
128-bit AES
Interface Type
USB 2.0
Password protection, sliding lid
AES-128
Software Included
60.2 mm
20.8 mm
11.2 mm
-25 °C
85 °C
