This cable gives you the option of connecting a DVI device to your HDMI screen or vice versa. And this means that if you want to, you could connect your computer with its DVI output to your flat screen with HDMI input. Note that this cable can only transmit video and therefore cannot be used to transmit audio.
- Sandberg adapter cable - 2 m
- Cable
- Adapter cable
- Technology
- Double shielded
- Length
- 2 m
- Connector
- DVI-D - male
- Connector (Second End)
- HDMI - male
- Cable Type
- Adapter cable
- Technology
- Double shielded
- Length
- 2 m
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- 19 pin HDMI Type A - male
