This DVI-D Single-Link cable allows you to connect a DVI screen digitally with a maximum resolution of 1920 x 1080. The cable is double-shielded and uses ferrite cores to suppress noise and ensure optimum image quality. Note that this cable cannot be used to transmit analog VGA signals.
- Sandberg DVI cable - 1 m
- DVI cable
- Technology
- Double shielded
- Length
- 1 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- 5-year warranty
- DVI cable
- Technology
- Double shielded
- Length
- 1 m
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- 5-year warranty
