Designed & engineered to bring the life to the party
Boost your party with incredible 1500W sound.
Built-in Woofer
Feel the enhanced bass performance with a long excursion bass unit through a 10 inch built-in woofer. Take your party anthems to the next level and enjoy deep bass for those dance floor filling tunes.
Bi-directional Sound
Disperse sound and experience wider soundstage that fills your party. Never be on the wrong side of the dancefloor and enjoy the music from whichever side you are on with bi-directional and room-filling sound.
LED Party Lights
Discover LED disco lights that can change colour to suit you. Take control with your mobile device or set them so they match the beat of the music. Create an awesome atmosphere with customisable lights, patterns and colours.
Wall-to-wall sound
Uniquely designed bi-directional speakers fill any space with 1500 watts of high-power audio. -
Feel the bass drop
The built-in 10-inch woofer you won't just hear, you'll feel. -
LED Party Lights
Create the right setting for any mood with various light modes including Party, Ambient, and Dance. -
Karaoke Mode
With two mic inputs, you and a friend can sing your hearts out with Karaoke Mode. -
Be the DJ
Set the right vibe! Download the app to adjust the built-in LED lighting, sound effects, and even your EQ settings - right from your Android or iOS device. -
Sync devices and synchronize sound
Need even bigger sound? Fill the entire room by connecting multiple Samsung Sound Tower devices for a more immersive sound experience. -
Double the fun
With Bluetooth Multi Connection, you and your friend can connect and pair two mobile devices simultaneously. Alternate between two separate devices without disconnecting. -
Bring the bass
Boost the bass with the touch of a button. -
Poolside-ready
With a spill resistant top-panel, you don't have to worry about accidental drips and splashes.
- Samsung Giga Party Audio MX-T70 - party speaker - wireless
- Product Type
- Party speaker - 2.1-channel
- Media Content Source
- USB-host
- Karaoke
- Protection
- Water-resistant
- Speaker Type
- Active
- Continuous Power
- 1500 Watt
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC
- Speaker Details
- Speaker - stereo x 2 - 450 Watt - 2-way - active , Speaker - subwoofer - 600 Watt - active
- Black
- Built-in Decoders
- aptX
- Sound Effects
- DJ effect
- 46.3 cm x 45.5 cm x 88.4 cm
- 26.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Karaoke, Wireless Party Chain
- USB-host
- Light
- Multicolour LED light
- Protection
- Water-resistant
- Enclosure Colour
- Black
Speaker System
- Speaker Type
- Active
- Continuous Power
- 1500 Watt
- Amplifier
- Integrated
- Sound Effects
- DJ effect
- Bluetooth 5.0
- Bluetooth Audio Codec
- SBC
- Built-in Decoders
- aptX
- Audio Formats
- Controls
- Bass boost
- App-Controlled
Speaker System Details
- Speaker Details
- Driver Details
- Speaker: subwoofer driver - 10" , Speaker: 2 x mid/woofer driver - 5.25" , Speaker: 2 x tweeter driver - 1"
- Connector Type
- 2 x USB (4 PIN USB Type A) , 2 x microphone (phone 6.3 mm) , Audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) , Audio line-out (RCA x 2)
- Included Accessories
- Remote control
- ENERGY STAR Certified
- Power Source
- Integrated power supply
- 46.3 cm
- 45.5 cm
- 88.4 cm
- 26.5 kg
