Samsung ML-4510ND Network Ready Mono Laser (Black & White) Printer with Duplex
Quicklinx: 7M0VWS00 Mfr#: ML-4510ND/SEE
Delivering a business print solution that answer both simplicity and productivity needs can be a challenge, especially across today's diverse business environment. With hassle-free integration and easy-to-use functionality, the Samsung Mono Laser Printer ML-5510 / 6510 series delivers amazing productivity. This is helped by the new larger paper capacity and the enhanced printing speeds. With the ML-5510ND, work will have never seemed so streamlined and efficient.
-High Performance Office Productivity
The ML-5510ND increases your productivity with a print speed of 52ppm in A4. If its breathtakingly fast printing speed isn't enough, when you factor in the processing power that comes with an 700MHz processor, Gigabit network and memory expandable up to 768MB,, there's no doubting the high-octane performance the ML-5510ND can bring to any office.
-Connectivity at the Touch of a Button
Connect everyone in your office to one network and keep everything running smoothly. They'll share a common printer and you'll save time from servicing multiple machines. And with the Gigabit LAN you can increase your performance by hooking it up to the network. Improve your communication skills with the ML-5510ND laser printer and keep your lines of communication open.
-Convenient One-Touch Eco Mode
One touch of the ECO button lets you print using less toner on each page to extend the life of toner cartridge and administrator can modify for more eco-friendly print setting for multiple pages per sheet and duplex mode with toner save mode. And it doesn't stop there. With the unique Result Simulator you can see exactly how much CO2, electricity and paper you have saved with the settings you've selected. Giving you real insight into the positive impact the Samsung ML-5510ND is having on your costs and the environment too .
-Totally adaptable, Easily Customisable
The Samsung ML-5510ND can be customised to suit your business needs. With a fully modular setup and plenty of expandability options, this printer meets the exact needs of your business.
-Maximum Paper Input
Feel free to multitask while your documents print: the ML-5510ND will crank through even your biggest print jobs without relying on you for a paper refill. Upgrade the standard 520-page capacity cassette and 100-page multi-purpose tray with 520-page optional second cassettes and 2000-page high capacity feeder for even larger capacity paper handling, perfect for all of your bulk printing needs. Sometimes, bigger really is better.
-One less noisy office distraction
You shouldn't have to struggle to hear yourself think while sitting at your own desk. That's why the Samsung ML-5510ND is engineered to be whisper quiet, generating a noise level of just 55 dBA while it's printing. That's less than the gentle hum of a running refrigerator! A desktop printer that does its work while letting you focus on yours? Cool.
- The printer that works with your budget
The ML-5510ND lets you choose the right consumables option which you can afford. Toner cartridges are available in cost-effective standard-yield 10000-page version and high yield 30000-page version which provide a lower cost per page and require fewer replacements.
  • Free your day with a reliable printing
    Set your workday free from time-consuming and stress-causing printer blocks with Samsung's anti-jam technology. Utilising a retard roller, which provides a backward friction during the paper pickup process, your operation will see increases in productivity and even bigger reductions in work frustration. Common problems that often add to stress-levels, such as miss-feeding and multiple paper feeding from the cassette tray, will become things of the past. An impressive high monthly duty is one of the clear-cut and measurable benefits found with anti-jam technology, and will add to a more streamlined and reliable workflow. So, with Samsung anti-jam technology your printing operation can finally be hassle-free, efficient and reliable.
  • Streamline work with easy-to-use printers
    Settle for nothing less than brilliant printing solutions that are trouble-free. The simple OP panel, which features a new compass dial, a 4-line LCD display and a numeric keypad, provides a simple and easy way to take full control of your printing operation. Featuring a new one-touch convenience eco button, which is easily found on the front panel and acts as a default setting once turned on, you can now combine two pages into one document. This helps you cut-back on costs by reducing paper and toner use, and therefore also lessens your impact on the environment. The OP panel also simplifies your workflow, with fewer buttons and unnecessary options to worry about. You can really produce amazing results in no time at all.
  • A top printer that's low on noise
    From a company that knows its business, the new Samsung ML-4510ND printer can work flat out at a mere 54 decibels, an office-friendly volume you won‘t be hearingcompetitors shout about. With a standby volume of 30dBA, it signals an end to colleagues having to scream to be heard, even before their printing has begun. Doors can stay open along corridors as the ML-4510ND outperforms the other leading printers copy after copy.
  • Being eco-friendly just got easier
    Make hitting your environmental goals a whole lot easier with Samsung's new Eco Mode, which also includes a Results Simulator to check how well you are doing. The Eco Mode features a one touch Eco Button, which conveniently serves as your default setting once activated, and reduces paper consumption with Duplex printing, 2-up printing and a Toner Save setting. Thanks to the Results Simulator, you can really appreciate how much good work you are doing. The simulation shows levels of carbon dioxide emissions, electricity and paper usage. The Eco Mode is an easy and effective way of keeping track of your printer consumption – which is better for you and the planet!
  • Low cost per page, saving you money.-selected
    Whether your office is big or small, the Samsung ML-4510ND printer will continue to deliver the best copy at a budget price. Save on money due to the separated toner and drum. Also, utilising a polymerised toner, the Samsung ML-4510ND printer lowers power consumption; its thin and uniform toner layer wastes less toner while operating with a lower fusing temperature and thus requires less power. So, the Samsung ML-4510ND printer delivers the perfect combination of professional printing that also saves you money, which is very business smart.
Samsung ML-4510ND - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
26.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 43 ppm - B/W - A4 (210 x 297 mm) , Up to 45 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB, Gigabit LAN, USB host
Samsung 600 MHz
RAM Installed (Max)
128 MB (640 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, IBM ProPrinter, XPS, EPSON, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, cards, bond paper
Total Media Capacity
620 sheets
Media Handling
100-sheet multipurpose tray, 520-sheet input tray
Monthly Duty Cycle (max)
150000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
Microsoft Windows 2000, Debian Linux, Red Hat Enterprise Linux WS, Red Hat Fedora Core 1, Red Hat Fedora Core 2, Red Hat Fedora Core 4, SuSE Linux 10.0, Red Hat Fedora Core 3, Red Hat Fedora Core 9, Red Hat Fedora Core 10, Ubuntu 8.10, Ubuntu 9.04, Ubuntu 6.06, SUSE Linux Enterprise Desktop 11, Apple MacOS X 10.3 - 10.6, SuSE Linux 10.1, SUSE Linux Enterprise Desktop 10, Red Hat Fedora Core 5, Mandriva Linux, Ubuntu 5.10, Red Hat Fedora Core 6, openSUSE 10.2, openSUSE 10.3, openSUSE 10.1, openSUSE 10.0, Red Hat Fedora Core 7, Red Hat Fedora Core 8, Ubuntu 5.04, Ubuntu 6.10, Ubuntu 8.04, Ubuntu 9.10, Red Hat Fedora Core 11, Red Hat Fedora Core 12, Ubuntu 7.10, Microsoft Windows Server 2008 R2 x64 Edition, Ubuntu 7.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
Microsoft Certification
Compatible with Windows 7
41.8 cm x 43.5 cm x 35.8 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 dpi
Automatic Duplexing
First Print Out Time B/W
7 sec
Language Simulation
Media Handling
Samsung 600 MHz
RAM
RAM Installed (Max)
128 MB / 640 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
620 sheets
Media Feeders
1 x automatic - 520 sheets , 1 x manual - 100 sheets
Output Trays Capacity
500 sheets
Duty Cycle
150000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x direct print port - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black)
Supported Windows 7 Features
Windows HD Imaging
Power supply - internal
850 Watt
Power Consumption Stand by / Sleep
4.5 Watt
Software Included
Drivers & Utilities
Sound Emission (Idle)
30 dB
Sound Emission (Operating)
54 dB
41.8 cm
43.5 cm
35.8 cm
26.5 kg
Width (Shipping)
58 cm
Depth (Shipping)
56 cm
Height (Shipping)
62 cm
