A perfect fit - both in life and your pocket. A brilliant Flex Window you can customize. A camera that captures selfies from edgy angles. Plus, a battery that keeps up.
Flex Window, the large cover screen on a Galaxy Z Flip
Galaxy Z Flip5 has a 3.4-inch Flex Window built for self expression. Compact and eye-catching from every angle, this foldable is as versatile as it is portable. -
Camera, good selfie experience on a Galaxy smartphone
Capture stunning selfies with FlexCam and make any angle your good. No matter which camera you choose, Galaxy Z Flip5 makes it easy. All you have left to do is master the art of the pose. -
Meet the 3.4" Flex Window
Reply to messages with a QWERTY keyboard, make calls, check the weather forecast and even pull out your wallet - all from a big, bright Flex Window. Featuring more clock faces and crisscross gestures you know from across the Galaxy ecosystem. And no matter how many widgets you use, you'll never get lost in the shuffle with Multi Widget View. -
All-day battery life
Backed up by a powerful processor, this battery is even more efficient, stretching out the charge so you can keep binging movies or gaming late into the night. Need extra juice? Enable low power mode to keep the fun flowing. -
The powerful processor on Galaxy foldables
The Snapdragon 8 Gen 2 Mobile Platform for Galaxy takes you to a whole high level of power. Experience smoother graphics, faster AI and improved battery performance. -
An flex, Flex Mode Panel
Level up how you use Flex Mode with more controls at your fingertips. Hide or expand the panel with the touch of a button. You can even whip out a touchpad and curser. And an enhanced playback control panel makes navigating through music and media easier and more precise than ever. -
Durable to keep you flipping
Galaxy Z Flip5 stays tough. And with the added support of Samsung Care+, take it with you without worrying about whatever slip-ups may happen along the way.
- Samsung Galaxy Z Flip5 - graphite - 5G smartphone - 512 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-F731B
- Display
- OLED display - 2640 x 1080 pixels - 6.7" - (120 Hz) - 22:9 - Dynamic AMOLED 2X - inward - foldable
- Display (2nd)
- OLED display - colour - 3.4"
- Processor
- Qualcomm Snapdragon 8 Gen 2 3.36 GHz (8-core)
- Memory
- RAM 8 GB / 512 GB
- Operating System
- Android 13 with One UI 5.1.1
- Main Camera
- 12 Megapixel - wide-angle lens - f/1.8 - focus: automatic
- Second Camera
- 12 Megapixel - ultra wide-angle lens - f/2.2
- Front Camera
- 10 Megapixel f/2.2 - focus free
- Service Provider
- Not specified
- Form Factor
- Folder (flip) - touch screen, dual screen
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 6, Wi-Fi 6E, Bluetooth
- Security Devices
- Face recognition, fingerprint reader (side)
- Connectors
- USB-C
- Talk Time
- Up to 2100 minutes
- Wireless Charging Standards
- WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Water-resistant
- Graphite
- 71.9 mm x 6.9 mm x 165.1 mm
- 187 g
- Repairability Index
- 8 (out of 10)
- Specific Absorption Rate (SAR)
- 0.601 W/kg (head) , 1.451 W/kg (body) , 2.34 W/kg (limb)
- Product Type
- Smartphone
- SM-F731B
- Form Factor
- Protection
- Water-resistant
- 71.9 mm
- 6.9 mm
- 165.1 mm
- 187 g
- Dimensions Details
- Unfolded - 71.9 mm x 6.9 mm x 165.1 mm , Folded - 71.9 mm x 15.1 mm x 85.1 mm
- Body Colour
- Graphite
- Body Material
- Armor aluminium, Corning Gorilla Glass Victus 2
- SAR Value
- 2.34 W/kg (limb), 1.451 W/kg (body), 0.601 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 13
- User Interface
- One UI 5.1.1
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Communications
- Data Transmission
- LTE, FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n75, n77, n78, n40, n25, n12
- 5G NR Frequency
- FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, SDL DL 1500+, TDD TD 3700, TDD TD 3500, TDD 2300, FDD 1900, n12
- NFC, IEEE 802.11a/b/g/n/ac/ax, Wi-Fi 6E, Bluetooth 5.3
Phone Features
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
- Security Devices
- Additional Features
- MIMO technology, Samsung KNOX, Samsung Smart Switch, Flex mode, Flex Window, Multi Widget View, Flex Hinge
Media Player
- Supported Digital Audio Standards
- WAV, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Clock Speed
- 3.36 GHz
- Processor Core Qty
- 8-core
- RAM
- 8 GB
- Internal Memory Capacity
- 512 GB
- User Memory
- 453.7 GB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Focus free
- Field of View (FoV)
- 85 degree(s)
- Pixel Size
- 1.22 µm
Main Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.8
- 83 degree(s)
- Pixel Size
- 1.8 µm
- Focus Adjustment
- Automatic
- Digital Zoom
- 10x
- Camera Modes
- Nightography
- Light Source
- LED flash
- Video Resolutions
- 3840 x 2160 (4K) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, Slo-mo video 1920 x 1080 (1080p) at 960 fps
- Dual Pixel Autofocus technology, FlexCam
Second Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 123 degree(s)
- Pixel Size
- 1.12 µm
Display
- OLED display
- Technology
- Dynamic AMOLED 2X
- Diagonal Size
- 6.7"
- Display Resolution
- Display Format
- Full HD+
- Foldable
- Design
- Inward folding
- Aspect Ratio
- 22:9
- Max Brightness
- 1750 cd/m²
- Colour Depth
- 16.7 million colours
- Refresh Rate
- 120 Hz
- Video Wallpaper
Display (2nd)
- Diagonal Size
- 3.4"
- 720 x 748 pixels
- Colour Depth
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 3700 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Adaptive Fast Charging
- Wireless Charging
- Talk Time
- 2100 minutes
- Run Time Details
- Talk (4G): up to 2100 min , Active online usage (LTE): up to 17 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (wireless video): up to 20 hrs , Playback (wireless audio): up to 57 hrs
- VDE, IPX8, USB 3.2 Gen 1, Android Audio Streaming for Hearing Aid (ASHA)
- Included Accessories
- SIM card removal tool, USB-C cable
Sustainability Information
- 8 (out of 10)
- Max Depth of Water Resistance
- 1.5 m
Samsung Galaxy Z Flip5 Leather Case | In Stock | £46.13 |
