Go faster with Galaxy A42 5G
On the next-generation mobile data network, the power of 5G fast speeds change the way you experience and share content—from super-smooth gaming and streaming, to ultra-fast sharing and downloading. Upgrade to the Galaxy A42 5G and speed up your smartphone experience.
Maximise your view to the fullest
Expand your view to the 6.6-inch Infinity-U Display of Galaxy A42 5G and enjoy an uninterrupted view of everything you love. Thanks to Super AMOLED technology, your everyday content always looks its best—sharp, crisp and clear.
Advanced Quad Camera, advanced photography powers
Start with the 48MP Main Camera to capture life's moments with more clarity. Expand the viewing angle with Ultra Wide Camera. Customise focus with Depth Camera, or get closer to the details with Macro Camera.
Power that keeps you going
Stay ahead of the day with a battery that won't slow you down. A 5,000mAh (typical) battery lets you continue what you're doing without worrying about the battery bar. And with up to 15W of Adaptive Fast Charging, Galaxy A42 5G gets back to full power quickly.
Give yourself more room to play
Galaxy A42 5G combines Octa-core processing power with up to 8GB of RAM for fast and efficient performance for the task at hand. Enjoy 128GB of internal storage or add even more space with a 1TB microSD card.
Maximize your view to the fullest
Expand your view to the 6.6-inch Infinity-U display of Galaxy A42 5G and enjoy an uninterrupted view of everything you love. Thanks to Super AMOLED technology, your everyday content always looks its best - sharp, crisp and clear. -
A glossy back that's comfortable to hold
Galaxy A42 5G's sleek design gives it an eye-catching, prismatic look. Refined curves make it comfortable to hold and provide easy screen navigation. -
Advanced quad camera, advanced photography powers
Start with the 48MP main camera to capture life's moments with more clarity. Expand the viewing angle with ultrawide camera. Customize focus with depth camera, or get closer to the details with macro camera. -
Ultrawide camera, ultrawide moments
Similar to human eyesight, the 8MP ultrawide camera sees the world with a 123-degree angle of view, adding more perspective to everything you shoot. -
Macro camera pays attention to the tiny details
Get in close with the 5MP macro camera and bring out the ultrafine details in your picture. It applies natural bokeh effect to your pictures, allowing your subject to stand out from the background. -
Bring the focus to the front with depth camera
The 5MP depth camera lets you adjust the depth of field in your photos. With a simple touch, you can easily fine-tune the background blur behind your subject for high-quality portrait shots that truly stand out. -
Front camera, attention-grabbing selfies
With the Galaxy A42 5G 20MP front camera and live focus, it's easy to snap stunning selfies that feature more you and less background. -
Stay ahead of the day with a battery that won't slow you down. A 5,000mAh battery lets you continue what you're doing without worrying about the battery bar. And with up to 15W of adaptive fast charging, Galaxy A42 5G gets back to full power quickly. -
Game Booster gives you the edge
Maximize performance with Game Booster. Cut distractions and up your game with a dedicated interface and easy to reach menu. Frame booster gives graphics smooth, lifelike motion. And play at your best as Game Booster learns your usage patterns to optimize battery, temperature and memory. -
Defense-grade security
Built into the phone's hardware and software from the start, Samsung KNOX protects your phone from the minute it's turned on. Offering multilayered security, it defends your most sensitive information from malware and malicious threats. -
Made to focus with One UI Core
One UI Core helps you focus on what matters to you. Hardware and software work together, giving you content and features at your fingertips so you can get to them faster. Use night mode for a comfortable experience in the dark, and with clear and intuitive visuals using your phone is like second nature.
- Samsung Galaxy A42 5G - prism dot white - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-A426B/DS
- Display
- OLED display - 1600 x 720 pixels - 6.6" - Super AMOLED
- Processor
- 2.2 GHz (8-core)
- Memory
- RAM 4 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- Google Android with One UI
- Main Camera
- 48 Megapixel - f/1.8 - focus: automatic
- Second Camera
- 8 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 5 Megapixel - f/2.4 - macro camera
- Fourth Camera
- 5 Megapixel - f/2.4 - depth camera
- Front Camera
- 20 Megapixel f/2.2 - focus free
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 2160 minutes
- Prism dot white
- 75.9 mm x 8.6 mm x 164.4 mm
- 193 g
- Specific Absorption Rate (SAR)
- 1.154 W/kg (head) , 1.334 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-A426B/DS
- Form Factor
- Touch
- 75.9 mm
- 8.6 mm
- 164.4 mm
- 193 g
- Body Colour
- Prism dot white
- SAR Value
- 1.334 W/kg (body), 1.154 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Google Android
- User Interface
- One UI
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- SIM Card Configuration Details
- Nano SIM + nano SIM/microSD
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 28, Band 38, Band 40, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
- 5G NR Band
- N1, n3, n5, n7, n8, n28, n41, n78, n40
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 700APT, TDD TD 2500, TDD TD 3500, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, gyro sensor, geomagnetic sensor, light sensor
- Security Devices
- Additional Features
- Samsung KNOX, Game Booster
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
- Clock Speed
- 2.2 GHz
- Processor Core Qty
- 8-core
- RAM
- 4 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 106 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 20 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Focus free
- Camera Modes
- Live Focus mode
- Video Resolutions
- 3840 x 2160 (4K) at 30 fps
Main Camera
- Sensor Resolution
- 48 Megapixel
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic
- Digital Zoom
- 10x
- Special Effects
- Bokeh effect
- Camera Modes
- Live Focus mode
- Light Source
- Flash
- Video Resolutions
- Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps, Slo-mo video 1280 x 720 (720p) at 480 fps
Second Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Field of View (FoV)
- 123 degree(s)
Third Camera
- Sensor Resolution
- 5 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Macro camera
Fourth Camera
- Sensor Resolution
- 5 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Depth camera
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 6.6"
- Display Resolution
- 1600 x 720 pixels
- Display Format
- HD+
- Colour Depth
- 16.7 million colours
- Night mode, Edge-to-Edge screen, Infinity U Display
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 5000 mAh
- Fast Charging Technology
- Adaptive Fast Charging
- Talk Time
- 2160 minutes
- Run Time Details
- Active online usage (LTE): up to 21 hrs , Active online usage (Wi-Fi): up to 22 hrs , Playback (audio): up to 130 hrs , Talk (4G): up to 2160 min , Playback (video): up to 34 hrs
- Included Accessories
- Power adapter
- Limited warranty - 2 years
