Samsung CLX 3305FN Colour Laser Multifunction Printer
Quicklinx: 83L3WS00 Mfr#: CLX-3305FN/SEE
Choose a Samsung CLX-3305FN Colour Laser Multifunction Printer and maximise your print quality – as well as your workspace. You can print, copy, fax and scan at the touch of a button. Not only that, but Samsung's ReCP technology and new polymerised toner make sure that your printouts are more vivid, crisp and vibrant than ever. And, thanks to compact ergonomic design, the CLX-3305FN even takes up less space.
  • Easy to use
    Designed for simple and intuitive operation the CLX-3305FN saves you precious time and effort. One Touch Eco ButtonJust One push of the ECO button and you can save on toner, paper, and energy. Print multiple pages on one sheet, change colour to greyscale or skip blank pages. One Touch Print Screen ButtonPrint exactly what you see on the screen with just one click, saving time. One Touch WPS ButtonConnect quickly and securely to your wireless network with the touch of a button, via the one-touch WPS (Wi-Fi Protected Setup).
  • 4-in-1 Multifunction
    One push of the ECO button and you can save paper and energy straightaway. Print more onto every page, including 2-up, 4-up and duplex. Easy Document Creator is an application to help you compile and share large documents or other scanned or faxed information digitally. Print exactly what you see on the screen with just one click, saving time. Connect quickly and securely to your wireless network with the touch of a button, via the CLX-3305FN Wi-Fi Protected Setup (WPS).
  • Enjoy quality printouts
    Samsung's unique ReCP (Rendering Engine for Clean Page) Technology improves the overall quality and vibrancy of your colour printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
  • Polymerized toner
    Our newly developed polymerized toner has smaller and more uniform particles than conventional toner. Meaning, your printouts will have crisper lines and more vivid colours - helping avoid any paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading.
  • Ergonomic design
    Don't worry about this printer crowding your space. Its beautiful and compact design makes it a pleasure to share a desk with. Small size FootprintWith a footprint of just 40.6 x 36.2cm, it's the world's smallest colour laser MFP. Ergonomic designIts ergonomic design with ebony brown and ice grey colour creates a modern and elegant work environments.
Samsung CLX-3305FN - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
20000 impressions
Max Copying Speed
Up to 18 ppm (mono) / up to 4 ppm (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
600 x 600 dpi
Original Size
148 mm width (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Media Size
76 x 152.4 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, cards, labels, recycled paper, thin paper, thick paper
Standard Media Capacity
150 sheets
Output Trays Capacity
50 sheets
Connection Availability
USB 2.0, LAN, USB host
Office Machine Features
Save to USB flash drive, scan to folder, scan to application
40.6 cm x 36.2 cm x 33.35 cm
13.98 kg
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
20000 impressions
Display
2 lines
Standard Memory
128 MB 128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PostScript 3, PCL 5c, SPLC, UFRII LT, PCL 6C
First Print Out Time B/W
14 sec
First Print Out Time Colour
26 sec
Scanning
Scan Element
CIS
Optical Resolution
600 x 600 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Caller ID
Automatic redialing, last number redial
Document & Media Handling
Min Original Size
148 mm width
Max Original Size
Original Type
Sheets
Min Media Size
76 x 152.4 mm
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
150 sheets
50 sheets
Paper cassette - 150 sheets - Legal (216 x 356 mm) , Output tray - 50 sheets , ADF - Legal (216 x 356 mm)
Speed Details
Printing: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - B/W , Printing: up to 4 ppm (A4) - colour , Copying: up to 4 ppm (A4) - colour , Printing: up to 19 ppm (Letter A) - B/W , Printing: up to 4 ppm (Letter A) - colour , Copying: up to 19 ppm (Letter A) - B/W , Copying: up to 4 ppm (Letter A) - colour
1 x USB 2.0 , 1 x USB host , 1 x LAN
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.4 - 10.7
290 Watt
Power Consumption Standby
60 Watt
Power Consumption Sleep
1.6 Watt
First Copy Out Time B/W
14 sec
First Copy Out Time Colour
36 sec
Consumables Included
1 x toner cartridge (black) - up to 700 pages , 1 x toner cartridge (yellow) - up to 500 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages
ISO 19798
40.6 cm
36.2 cm
33.35 cm
13.98 kg
Sound Emission
53 dBA (operating)
