Let the beat drop, not your Buds. Advanced wingtip design makes sure your sound fits just right.
Ear-friendly design
Listen in comfort throughout your day with a redesigned wingtip that keeps your Buds securely in place. -
Easy touch and secure grip
Control your Buds FE with clearly defined areas for tapping and gripping. It's easy to secure them, pause the audio and change the volume with a simple tap. -
Design that fits your style
Sleek and versatile for any occasion. Timeless design goes with any outfit so you can focus on the music, not matching. -
Hear what you want, not what you don't
Immerse yourself in the sounds you love. Active Noise Cancellation minimizes distracting sounds in your environment, from background chatter to airplanes flying overhead. -
Hear loud and clear
Every phone call is crystal clear with Buds. Powerful speakers with deep, rich bass help you hear every word, while Ambient sound mode lets in outside noises so you can still stay alert of your surroundings. Keep your music playing for up to 30 hours with Active Noise Canceling turned off, or up to 21 hours with it on.
- Samsung Galaxy Buds FE - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- White
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Effects
- Ambient Sound Mode
- Active Noise Canceling
- Microphones Included
- 6
- Platform
- SmartThings
- Intelligent Assistant
- Bixby - indirect
- Specific Absorption Rate (SAR)
- 0.294 W/kg (head)
- Product Type
- True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
- Earbud: 1.71 cm x 2.22 cm x 1.92 cm / 5.6 g , Charging case: 5 cm x 2.77 cm x 5 cm / 40 g
- White
- Recommended Use
- Touch control
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC, SSC (Samsung Seamless Codec)
- Bluetooth Version
- Bluetooth 5.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Effects
Microphone
- Form Factor
- Built-in
- 6
Tracking
- Sensors
- Proximity sensor, hall sensor, touch sensor
- Connector Type
- Bluetooth , USB (power only) (24 pin USB-C)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- SmartThings
- Bixby
- Voice Controlled
- Indirect
- Included Accessories
- 3 pairs of silicone ear tips (S, M, L), charging case (479 mAh), 2 pairs of wing tips (S/M, M/L)
- Cable Details
- USB-C charge cable - detachable
- 0.294 W/kg (head)
- Battery
- Headphone battery rechargeable
- Capacity
- 60 mAh
- Run Time (Up To)
- 6 hour(s)
- Run Time Details
- Continuous playback (noise cancelling ON): up to 6 hours , Continuous playback (with included charging case): up to 30 hours , Continuous playback (noise cancelling ON / with included charging case): up to 21 hours , Continuous talk: up to 4 hours , Continuous talk (with included charging case): up to 14 hours , Continuous talk (noise cancelling ON): up to 3.5 hours , Continuous talk (noise cancelling ON / with included charging case): up to 13 hours , Continuous playback: up to 8.5 hours
