Experience amazing Samsung plasma picture quality
Using an advanced picture quality improvement algorithm, Samsung's Wide Colour Enhancer Plus drastically improves the quality of any image and uncovers hidden details. Now see colours as they were meant to be seen with Wide Colour Enhancer Plus.
Samsung's 600Hz Subfield Motion technology, flashes a single image up to 600 times a second. The result is smoother images with unprecedented picture quality, no matter how fast the images are moving.
Feel like you're actually in the stadium cheering on your favourite team with Samsung's Football Mode. At the press of a button it optimises picture and sound settings for a better football viewing experience.
Cinema smooth technology significantly reduces motion judder from your Blu-ray player so you can enjoy your movie experience the way the Director intended it to be viewed.
Freeview is a free to air digital service built into your TV to offer more choice with free access to over 50 TV channels , so now there's always something to watch!
ConnectShareâ„¢ Movie lets you watch videos, play music or view photos from a USB connection without needing to use a PC. Simply plug your USB drive directly into your Samsung TV's USB port and watch on the big screen with friends and family.
2 x HDMI connections: Get superior picture and sound from your HD source. The High-Definition Multimedia Interface (HDMI) is a digital connection that can transmit HD video and audio over a single cable. Use it to optimize the image quality when you connect your TV to high-definition sources such as an HD cable TV, satellite receiver, or Blu-ray player.
Wide Color Enhancer Plus
See richer colors as they were meant to be seen. -
Football Mode
With the touch of a button optimize video and audio settings, feel like you're in the stadium. -
Cinema Smooth
Reduced motion judder from your Blu-ray player for a sharper movie experience. -
ConnectShare Movie
Watch videos, play music or view photos from your USB device.
- Samsung PE51H4500 4 Series - 51" plasma TV
- Product Type
- Plasma TV
- Diagonal Class
- 51"
- High glossy cool grey
- Resolution
- 1024 x 768
- Frame Rate & Enhancement Technology
- 600Hz Subfield Motion
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T
- Multi-channel Preview
- Picture-in-picture (PIP)
- Speaker System
- 2 speakers
- Sound Effects
- DTS Studio Sound, DTS Premium Sound 5.1
- USB
- Included Accessories
- Samsung TM1240A remote control
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A
- 216 Watt
- Power Consumption (On mode)
- 97 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 135 kWh
- Dimensions (WxDxH) - without stand
- 118.52 cm x 5.57 cm x 70.21 cm
- 17.7 kg
- 1-year warranty
- Product Type
- Plasma TV
- Energy Class
- Class A
- 216 Watt
- 97 W
- 135 kWh
- Diagonal Class
- 51"
- Series
- 4 Series
- TV Tuner
- TV Tuner Presence
- Sensors
- Eco Sensor
- Video Interface
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- Modes
- Game mode, Football Mode
- Timer Functions
- Sleep, wake
- Protection
- Screen burn protection
- Dimensions
- Without stand
- 118.52 cm
- 5.57 cm
- 70.21 cm
- 17.7 kg
- Enclosure Colour
Display
- Resolution
- 1024 x 768
- Cinema Smooth Technology, Wide Color Enhancer Plus, USB Cloning, Clear Image Panel, Black Optimizer, Digital Clean View, Golden Bridge Lite User Interface, E-Manual, Mega Dynamic Contrast Ratio, Embeded POP
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 400 x 400 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
- Remote Control Model
- Samsung TM1240A
Audio System
- Digital Audio Format
- Dolby Digital output, DTS digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Down-firing Speaker, Auto Volume Leveller (AVL)
- Speakers
- 2 x main channel speaker - 10 Watt
- Driver Details
- Main channel speaker: 1 x full-range driver
Network & Internet Multimedia
- Connect & Share
- ConnectShare Movie
- Connector Type
- 2 x HDMI , Composite video / component video input , Audio line-in , USB 2.0 , SCART , Digital audio output (optical)
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Auto On/Off
- Limited warranty - 1 year
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 118.52 cm x 5.57 cm x 70.21 cm x 17.7 kg , Panel with stand - 118.52 cm x 23.5 cm x 78.3 cm x 19.1 kg
- Width (Shipping)
- 129.2 cm
- Depth (Shipping)
- 33 cm
- Height (Shipping)
- 81 cm
- Weight (Shipping)
- 24.5 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
