Robust protection
Equipped with up to 3 m to concrete drop protection and a durable design, this portable external hard drive is designed to withstand the rigors of daily use, ensuring your data is always safe. -
High-speed transfers
With an interface speed of 20 Gbps (USB 3.2 Gen 2x2) and a max data transfer rate of 2000 MB/s, transferring large files is swift and efficient, reducing wait times and enhancing productivity. -
Secure data encryption
The Samsung T9 features 256-bit AES hardware encryption, providing an extra layer of security for your sensitive information and peace of mind knowing your data is protected.
- Samsung T9 MU-PG2T0B - SSD - 2 TB - USB 3.2 Gen 2x2
- Solid state drive - external (portable)
- Capacity
- 2 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.2 Gen 2x2 - USB-C
- Data Transfer Rate
- 20 Gbps (USB 3.2 Gen 2x2)
- Password authentication, up to 3m to concrete drop protection
- Power Source
- USB bus
- Enclosure Colour
- Black
- 60 mm x 88 mm x 14 mm
- 122 g
- Localisation
- Europe
- 5-year warranty
- Capacity
- 2 TB
- 256-bit AES
- Interface
- USB 3.2 Gen 2x2
- 60 mm
- 88 mm
- 14 mm
- 122 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 2000 MB/s
- Internal Data Rate
- 2000 MBps (read) / 1950 MBps (write)
Expansion & Connectivity
- 1 x USB 3.2 Gen 2x2 - 24 pin USB-C
- Power Source
- USB bus
- OS Required
- Apple MacOS, Android, Windows
- Cables Included
- USB-C cable , USB-C to USB-A cable
- UL, TUV, VCCI, BSMI, CB, IC, FCC, KC, RoHS2, EAC, RCM, BIS, UKCA
- Enclosure Colour
- Black
- Localisation
- Europe
- Limited warranty - 5 years
- 0 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
