The Samsung Spinpoint M9T mobile SATA drive delivers high capacity in a thin design to give customers the ideal solution for external and mobile applications. The 2.5-inch drive is just 9.5mm thin and available in capacities of 1.5TB and 2TB.
- Max. 667GB formatted capacity per disk
- SATA Native Command Queuing feature
- TuMR/PMR head with FOD technology
- SATA 6Gb/s interface support
- Load/unload head technology
- ATA Security Mode feature set
- ATA S.M.A.R.T. feature set
- SilentSeek™
- NoiseGuard™
- Interface: SATA 6Gb/s (3Gb/s, 1.5Gb/s)
- Rotational Speed: 5400-RPM class
- Cache: 32MB
- Average Seek Time (typical): 12ms
- Average Latency: 5.6ms
- Drive Ready Time (typical)2: 3.5ms
- Media to/from Buffer (max): 169MB/s
- Buffer to/from Host (max): 600MB/s
- Nonrecoverable Read Error: 1 sector in 10E14 bits
- Controlled Ramp Load/Unload: >600,000
- Idle: 2.5 bels
- Performance Seek: 2.7 bels
- Voltage: +5V ± 5%
- Spin-up Current (max): 1000 mA
- Read/Write (avg)3: 2.3W
- Low Power Idle (avg): 0.7W
- Standby (avg): 0.18W
- Sleep (avg): 0.18W
- Height: 9.5mm ±0.2mm (0.374in ±0.008in)
- Width: 69.85mm ±0.25mm (2.75in ±0.010in)
- Length: 100.35mm +0.2/-0.25mm (3.951mm +0.008/-0.010in)
- Weight (max): 130g (0.29lb)
- Samsung SpinPoint M9T ST2000LM003 - hard drive - 2 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 32 MB
- Spindle Speed
- 5400 rpm
- Load/unload technology, NoiseGuard, SilentSeek technology, Native Command Queuing (NCQ), Tunnel Magneto-resistive Recording (TMR) Head Technology, Perpendicular Magnetic Recording (PMR), Flying On Demand (FOD) Technology, S.M.A.R.T.
- 69.85 mm x 100.35 mm x 9.5 mm
- 130 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 2 TB
- Form Factor
- 2.5" x 1/8H
- Interface
- SATA 6Gb/s
- Buffer Size
- 32 MB
- 69.85 mm
- 100.35 mm
- 9.5 mm
- 130 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 169 MBps
- Seek Time
- 12 ms (average)
- Average Latency
- 5.6 ms
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" x 1/8H
- 0 °C
- 60 °C
- 5 - 90% (non-condensing)
- Shock Tolerance
- 300 g @ 2ms half-sine pulse (operating) / 900 g @ 1ms half-sine pulse (non-operating)
- Vibration Tolerance
- 1.5 g @ RMS (random) (operating)
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.83 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £8.84 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £20.52 |
