The Samsung 840 is a high performance SSD designed for power users. Capable of delivering up to 98,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MDX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
- Capacity: 250GB
- Sequential Read: 540MB/s
- Sequential Write: 250MB/s
- Random Read (QD32, 4KB): 96,000 IOPS
- Random Write (QD32, 4KB): 62,000 IOPS
- Random Read (QD1, 4KB): 7,900 IOPS
- Random Write (QD1, 4KB): 29,000 IOPS
- Warranty: 3 Year
The single best upgrade for your PC
With its simple 3-Step migration solution and industry-leading IOPS performance, the Samsung SSD 840 Series is the single best upgrade you can make for your PC. Samsung's SmartMigration software takes the guesswork and headache out of moving your operating system and precious data to your new SSD. Once you're up and running, the 840 Series' amazing IOPS speeds empower you to multitask like never before. Upgrading to an SSD is the easiest and most economical way to breathe new life into an aging PC. Today, most PC performance woes are the result of slow read and write speeds on behalf of the main storage device, not a lack of CPU performance. Upgrading to a Samsung SSD 840 Series can breathe new life into your old PC by enhancing boot-up speed, application loading, and multi-tasking performance. -
Superior reliability
Samsung SSDs are designed and built completely in-house. The Samsung SSD 840 Series is optimized for exceptional, sustained performance and unrivaled reliability through its specially-engineered wear-leveling and garbage collection algorithms. -
Magician software
Samsung's Magician software has been completely redesigned with an extreme focus on usability. Magician makes it simple for users to maximize the performance and lifetime of their Samsung SSD. In addition, SSD Magician also provides system information and facilitates performance benchmarking, performance optimization, OS optimization, firmware updates, secure erasing, and over provisioning. Drive Health Status, Total Bytes Written (TBW), and Disk Scan & Error Reporting functionality make Magician one of the most useful storage utilities available.
- Samsung 840 Series MZ-7TD250 - SSD - 250 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 250 GB
- Form Factor
- 2.5" Ultra Slim Line
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, Secure Erase function, Garbage Collection technology, S.M.A.R.T.
- 69.85 mm x 100 mm x 7 mm
- 63.5 g
- 3-year warranty
- Capacity
- 250 GB
- Form Factor
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100 mm
- 7 mm
- 63.5 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 540 MBps (read) / 240 MBps (write)
- 4KB Random Read
- 95000 IOPS
- 4KB Random Write
- 44000 IOPS
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- Software Included
- Drivers & Utilities, Samsung Smart Migration Software, Samsung Magician Software 4.0
- OS Required
- Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits) SP2
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 5 - 95% (non-condensing)
- Shock Tolerance
- 1500 g @ 0.5ms (non-operating)
- Vibration Tolerance
- 2.17 g @ 7-800 Hz (operating) / 3.08 g @ 7-800 Hz (non-operating)
