Samsung 1TB T7 Shield USB 3.2 External SSD - Blue
Quicklinx: GYBGWS00 Mfr#: MU-PE1T0R/EU
Capacity: 1TB, 1TB
Interface: USB 3.2 Gen 2
Type: External hard drive
44 In Stock
£115.84 ex VAT
£139.00 inc VAT
  • Create at full speed
    Transfer huge files instantly. USB 3.2 Gen 2 and PCIe NVMe enable phenomenal sequential read/write speeds of 1,050/1,000 MB for lag-free editing from the drive. The high-tech rubber coating with Dynamic Thermal Guard controls heat to maintain stable performance even during large-scale projects.
  • Extremely rugged
    Ready for adventure. Shoot on location and wander through the wilderness, while being confident about the security of your data, especially against water and dust with IP65 certification. The rugged design and advanced exterior elastomer add extra durability, even withstanding a 3-meter drop.
  • For your everyday devices
    Connect to your everyday devices effortlessly: Macs, PCs, Android devices, game consoles and more. Add the comfort of ultra mobility to every aspect of your life.
  • Dare with style
    The T7 Shield gives you colossal space in elegant colors. The rubber coating prevents the T7 Shield from slipping out of your fingers. Take it all with you and do it in style.
Samsung T7 Shield MU-PE1T0R - SSD - 1 TB - USB 3.2 Gen 2
Solid state drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.2 Gen2)
Shock resistant
Power Source
USB bus
Enclosure Colour
Blue
88.15 mm x 13 mm x 59 mm
98.5 g
3-year warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 2
Shock resistant
88.15 mm
13 mm
59 mm
98.5 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
1050 MB/s
Expansion & Connectivity
1 x USB 3.2 Gen 2 - 24 pin USB-C
Power Source
USB bus
Microsoft Windows 7 or later, Android 5.0 or later, Apple MacOS X 10.10 or later
UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, IP65, KC, RoHS2
Enclosure Colour
Blue
Limited warranty - 3 years
Capacity: 1TB
Capacity: 1TB
Brand: Samsung
