Capture, store and protect the priceless moments of your life Evolve to the next small thing in digital media storage
In today's high-tech world, your work and your life are recorded on digital media. Everything about you and who you are is captured in a digital format. That's why it is essential to ensure every bit of that information is available to you when and where you need it. Important client files, cherished photos and videos of family and friends, and personal information, these "snapshots" of your life must be safely stored, protected and easily accessible.
- Capacity: 1.0TB
- Interface: Compatible with USB 3.0, 2.0
- Dimensions (WxHxD): 71.0 x 9.2 x 53.2 mm
- Weight Max.: 30gram
- Transfer Speed: Up to 450MB/sec.
- UASP Mode: Support
- Encryption: AES 256-bit
- Security: Password setting (Optional)
- Certification: CE, BSMI, KC, VCCI, C-tick, FCC, IC, UL, TUV, CB
- RoHS Compliance: RoHS2
- Warranty: Limited 3-year
Enjoy faster speeds and safer data protection - wrapped in a stylish, compact package
Now you can rest assured when it comes to your data. There is a brand-new concept in external storage - a portable solid-state drive (SSD) - the T1 from Samsung. Designed with ground-breaking V-NAND technology, the T1 provides improved reliability and performance through its innovative architecture that vertically stacks memory cells. It's fast, safe and stylish. Consider it your Portable Portfolio. Everything on it shows who you are. The T1's sleek design will make you want to carry it around. However, it's not just its fancy-looking design that will impress you; the T1 will enhance your productivity with faster speeds and will bring you safer data protection thanks to Samsung's innovative V-NAND technology. So, get ready to upgrade your life from a hard disk drive (HDD) to the T1, your very own Portable Portfolio in an SSD - the next big trend in digital media storage.
Accelerate your life with V-NAND technology for instant feedback and fast read/write speeds
If speed is what you need, look no further. Powered by V-NAND technology and topped with the USB 3.0 high-speed interface and Samsung's innovative TurboWrite technology, the Portable SSD T1 boasts up to 450 megabytes per second (MB/s) sequential read/write speeds and response time as fast as an internal SSD. And its random read/write speeds are one hundred times faster than an external HDD. With this much of speeds, you can use the T1 as a second internal SSD without copying data from the external drive to a PC for work. That means you can save your precious time spent on data transfer and get on with your life. With up to 1 terabyte (TB) of data storage, you'll have enough room to store virtually everything you need.
Rest easy knowing all your files are protected from Keep your valuable data safe from unauthorized access and mishaps
When you've got your life recorded on your drive, there's nothing more agonizing than discovering your personal information has been accessed by an unauthorized person. Or that huge client project you've been working on for weeks has been destroyed because you accidently dropped your drive down a stairwell rushing to make your presentation. And let's not forget all those irreplaceable photos of your family - capturing your life's most precious moments - gone forever. Well, worry no more. Samsung's got you covered with the Portable SSD T1.
Advanced security and convenient setup
When you're using a portable drive, you need to be extra sure that it is protected for unwanted access. After all, what's on your drive is your business and nobody else's. The Portable SSD T1 is equipped with an AES-256-bit hardware-based, full-drive encryption algorithm to ensure your data files remain secure. And because it's hardware based, the encryption engine protects your data without performance degradation, which is often experienced with software-based encryptions. The embedded security enabling software features an intuitive user interface (UI) and easy setup. One password, full drive encryption software access, flash-based storage and Samsung SSD controller technology are all part of the package.
Shock resistance
Let's face it. Accidents happen. But when it involves your priceless data, you want to be sure you have some sort of safety net in the event you drop your drive. Samsung's engineers have designed the Portable SSD T1 to be highly durable and withstand virtually anything life throws at it. It can roll with the punches, protecting your data from hard knocks up to 1,500 G of shock and 20 G of vibration. Because of its memory-based storage, the Portable SSD T1 has no moving parts to get jostled around. So, it's safe enough to carry with you wherever you go.
Extreme temperature protection
When you're immersed in your work, you might not notice that your drive is overheating and struggling to keep up. With the Portable SSD T1, you don't have to sweat. The T1 will never overheat thanks to Dynamic Thermal Guard protection*. This protection monitors and maintains the drive's optimal operating temperature. Its throttling feature drops the SSD's temperature when necessary to protect your data and ensure the responsiveness you expect. So, you can relax, knowing that your portable SSD will not let you down.
Convey a professional image with the sleek, stylish profile of the Portable SSD T1
Everyone admires a trendsetter - stylish, sophisticated and always in the know. The Portable SSD T1, with its slim profile, high-tech design and incredible compact size, puts them on notice that you're on the cutting-edge of the next greatest thing in portable storage. Boasting a premium design that's optimized for portability, this small, lightweight SSD features an ultra-sleek finish that has a laser-patterned, textured surface punctuated by black chrome metallic accents. A thin, custom cable complements the SSD's avant-garde design.
Carry who you are in a portable portfolio
There's a new way to have your personal and professional data on you all the time. Ever heard of the T1? It's the portable SSD designed with V-NAND technology. We've carefully taken the powerful performance of an internal SSD, added the best security you can find and put it in a cool looking shell roughly the size of business card. The T1 is the perfect portable portfolio for your life in the digital world. -
Imagine if you never had to wait on your data
As you go through your day, why wait for data when you don't have to? With our T1 portable SSD you get superfast read-write speeds of up to 450 MB/s driven by TurboWrite technology. So you don't have to wait anymore. When tested head-to-head against a comparable external HDD the T1 demonstrated a data transfer speed 3 to 7 times faster. This means you save every second of your precious time when moving or retrieving files like movies, photos or applications. -
Focus on your life, not your data
For many people their data is their life whether it's personal or professional. That's why we've made sure the T1 is embedded with the latest in advanced security using an AES 256 bit encryption algorithm to secure valuable data. It's easy to use and can be accessed with one password. And the sturdy T1, which has no moving parts, can withstand 4x more shock and 40x more vibration than an external HDD. This along with resistance to high temperatures allows you to take it safely with you wherever you go. -
Bring style into your digital life
Let your portable portfolio be an expression of your trend setting style. The T1's sleek premium design is accentuated by its slim compact design, primed for chic portability. Plus, it has been designed with laser patterning and black chrome metalizing finishing. How cool does that sound? Even the T1 custom cable has been designed for style with its jet black color. -
A revolution in portable performance and reliability
You grow old, but your data storage doesn't have to. The T1's ground breaking V-NAND technology brings a new level of performance and reliability that had been impossible with conventional planar NAND memory. With the V-NAND technology, T1 will ensure revolutionary performance and reliability in portable data storage. -
Take your data wherever you go
You should have immediate access to your data any time you want it. Now, you can keep your data with you at all times thanks to the TI's compact, portable design. At 71.0 x 9.2 x 53.2 mm you can slide into your pocket, wallet or bag and you're good to go. Data storage has never been so portable.
- Samsung T1 MU-PS1T0B - solid state drive - 1 TB - USB 3.0
- Solid state drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Shock resistant, password authentication, 3D V-NAND Technology, TurboWrite Technology, 256-bit AES
- Power Source
- USB bus
- Enclosure Colour
- Black chrome
- 53.2 mm x 71 mm x 9.2 mm
- 30 g
- 3-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.0
- 53.2 mm
- 71 mm
- 9.2 mm
- 30 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 450 MB/s
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Power Source
- USB bus
- UL, TUV, C-Tick, BSMI, CB, IC, KC, RoHS2
- Enclosure Colour
- Black chrome
- Limited warranty - 3 years
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms
- Vibration Tolerance (operating)
- 20 g
