The compact way to add big space. Plug in the FIT Plus to get secondary, upgraded storage for your devices, then leave it in to easily carry more files wherever you go. It stays out of your way and is so quick it keeps files at the ready, all with USB 3.1 speeds and trusted reliability.
Store more
Extra storage that's always with you. The FIT Plus gives portability in a minimal profile, and is designed to seamlessly stay in your device, always ready for use. Keep it in laptops, smart TVs, and cars with reduced risk of accidental bumps or removal. -
Quick and ready
Save time, add space. Quick and convenient read speeds ensure transferring data never slows you down. -
Tough & trusted
Files stay secure, anywhere you go. FIT Plus is a trustworthy drive to store your valuable data. It works through it all with a waterproof, shock-proof, temperature-proof body.
- Samsung FIT Plus MUF-128AB - USB flash drive - 128 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1
- Storage Capacity
- 128 GB
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 128 GB
- Read Rate
- Up to 400 MB/s
- Write Rate
- Up to 60 MB/s
- Interface Type
- USB 3.1
- Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof
- Limited warranty - 5 years
- 23.6 mm
- 7.3 mm
- 18.8 mm
- 3.1 g
- -25 °C
- 85 °C
