The Samsung 830 Series Basic Kits Include SSD, Manual & Magician Software CD
The Samsung SSD 830 Series boasts superior random read speeds and faster sequential read and write speeds. It's the ideal solution for your everyday computing needs, such as web browsing, document creation, viewing or editing multimedia files, playing PC games, etc.
- Samsung 3-core MCX controller
- Samsung 2x nm Toggle DDR NAND Flash memory
- Samsung 256MB DDR2 SDRAM cache memory
- Magician software for SSD management
- Black-tone, brushed metal design
- Only 7mm thick to accommodate the latest slim-profile laptop PCs
Outstanding Performance in Multi-tasking
The Samsung SSD 830 Series boasts superior random read speeds (up to 80,000 IOPS) and faster sequential read and write speeds (up to 520 MB/s & 400 MB/s respectively). It's the ideal solution for your everyday computing needs, such as web browsing, document creation, viewing or editing multimedia files, playing PC games, etc.
Superior Reliability
As the world's #1 DRAM, NAND Flash, and SSD supplier, Samsung has unique, industry-leading engineering resources, technologies, and manufacturing processes as well as more stringent quality and testing standards. All Samsung SSDs are designed and built completely in-house, rather than sourcing generic parts from the market. The Samsung SSD 830 Series is optimized for exceptional, sustained performance and unrivaled reliability through its specially-engineered wear-leveling and garbage collection algorithms.
Industry-leading Design
The Samsung SSD 830 Series features stunning design and precision engineering - inside and out. It measures only 7mm thick, so it can even accommodate the latest ultra-slim laptop PCs.
Magician Software
Samsung's SSD Magician software eliminates the confusion and uncertainties of SSD management, making it simple for users to maximize the performance and lifetime of their Samsung SSD. The software helps to maintain the SSD at its peak condition, giving you the same great performance and reliability throughout the life of your PC. In addition to its performance maintenance features, SSD Magician also provides system information and facilitates performance benchmarking, performance optimization, OS optimization, firmware updates, secure erasing, and over provisioning.
Technical Specifications
- Dimensions (L* W* H): 100 x 69.85 x 7 (mm)
- Interface: SATA 6Gb/s (compatible with SATA 3Gb/s and SATA 1.5Gb/s)
- Form Factor: 2.5 inch
- NAND Flash Memory: 2x nm Samsung Toggle DDR MLC NAND Flash Memory
- Performance*: Sequential Read: Max. 520 MB/s (64GB/128GB/256GB/512GB)
- Sequential Write: Max. 400 MB/s (256GB/512GB)
- 4KB Random Read: Max. 80,000 IOPS (128GB/256GB/512GB)
- 4KB Random Write: Max. 36,000 IOPS (256GB/512GB)
- TRIM Support: Yes (Requires OS Support)
- Garbage Collection: Yes
- S.M.A.R.T: Yes
- Weight: Max. 62.5g (256GB/512GB)
- Reliability: 1.5 million hours MTBF (Mean Time Between Failures)
- Power Consumption: Active : 0.127W * (Typical) Idle : 0.078W** (Typical)
- Shock: 1500G & 0.5ms (Half sine)
Warranty: 3 years
Performance measurements based on Iometer with queue depth equal to 32. / * Active power is measured during execution of MobileMark 2007 in Windows 7 / ** DIPM enabled value
Optimised to perform well on both SATA 2 / SATA 3 interfaces
Optimised to perform well on both SATA 2 / SATA 3 interfaces. -
Design that delivers
The Samsung SSD 830 Series features stunning design and precision engineering – inside and out.Black-tone, brushed metal enclosure Super slim (7mm) for ultrabooks -
Magician software for sustained peak performance
Samsung's Magician Software makes it easy for you to maintain your SSD at its peak condition, giving you consistently great performance and reliability throughout the life of your PC.
- Samsung 830 Series MZ-7PC128B - SSD - 128 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 128 GB
- Form Factor
- 2.5" Ultra Slim Line
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- TRIM support, Garbage Collection technology, S.M.A.R.T.
- 69.85 mm x 100 mm x 7 mm
- 61 g
- 3-year warranty
- Capacity
- 128 GB
- Form Factor
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 69.85 mm
- 100 mm
- 7 mm
- 61 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 520 MBps (read) / 320 MBps (write)
- 4KB Random Read
- 80000 IOPS
- 4KB Random Write
- 30000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- Software Included
- Norton Ghost 15, Samsung Magician Software 3.0
- OS Required
- Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits)
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 5 - 95% (non-condensing)
- Shock Tolerance
- 1500 g @ 0.5ms (non-operating)
- Vibration Tolerance
- 2.17 g @ 7-800 Hz (operating) / 3.08 g @ 7-800 Hz (non-operating)
