Add Alarm Keypads to your second floor, garage and other areas to easily arm and disarm your Alarm system while indoors.
*Requires the Ring Alarm Base Station.
- Ring Alarm Keypad - control panel - Z-Wave - white
- Product Type
- Control panel
- Environment
- Indoor
- Functions
- Alarm control
- Power Source
- Battery, power adapter
- Connectivity
- Wireless - Z-Wave
- Input Type
- Keypad
- White
- 1-year warranty
- 14.9 cm x 2.3 cm x 10 cm
- Product Type
- Control panel
- Environment
- Indoor
- Functions
- Alarm control
- Power Source
- Connectivity Technology
- Wireless - Z-Wave
- Max Range Indoors
- 76.2 m
- Wall mountable, surface mountable, arm/disarm function
Control Unit
- Input Type
- Keypad
- Battery Lifetime
- 10 months
- Included Accessories
- Wall mount bracket
- White
- Warranty
- 1-year warranty
- 14.9 cm
- 2.3 cm
- 10 cm
- 0 °C
- 40 °C
