The Aficio™ SP100e is an affordable and stylish desktop black and white A4 laser printer. Its simplicity makes it ideal for a personal user who wants to utilise Ricoh's market leading technology.
Features:
13 page per minute A4 mono laser printer
Compact & Stylish design
Fast first print out at less than 13 seconds
16Mb for swift digital printing
Up to 1200 x 600 dpi equivalent resolution
50 sheet standard paper capacity
High speed USB 2 connectivity
Windows compatible
Ricoh reliability with target volume of 300 pages per month
Ricoh is one of the world's leading manufacturers of business printers. You can now reap the benefits of our know-how in high quality, great performance printer models designed for entry level users. Introducing: the new Ricoh Aficio™SP 100 e Series.
Specifications:
Warm-up time: 25 seconds First output speed: 13 seconds Continuous output speed: 13 pages per minute Dimensions (W x D x H): 402 x 368.5 x 119 mm Weight: 6.2 kg Power source: 220 - 240 V, 50/60 Hz Duty cycle: 10,000 prints per month Operating System Compatibility: Windows
- Ricoh SP 100e - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- Form Factor
- Desktop
- 6.2 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Max Media Size (Custom)
- 210 mm x 297 mm
- Print Speed
- Up to 13 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Interface
- USB
- Processor
- 80 MHz
- RAM Installed (Max)
- 16 MB (16 MB)
- Language Simulation
- Windows GDI driver
- Media Type
- Plain paper, recycled paper, thick paper, thin paper
- Total Media Capacity
- 50 sheets
- Media Handling
- 50-sheet input tray
- Monthly Duty Cycle (max)
- 10000 pages
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008
- 40.2 cm x 36.85 cm x 11.9 cm
- Printer Type
- Personal printer - laser - monochrome
- Form Factor
- Desktop
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 1200 x 600 dpi
- First Print Out Time B/W
- 13 sec
- Media Handling
- Processor
- 80 MHz
RAM
- 16 MB / 16 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- 210 mm x 297 mm
- Media Sizes
- A4 (210 x 297 mm)
- Media Weight
- 60 g/m² - 105 g/m²
- 50 sheets
- Output Trays Capacity
- 10 sheets
Duty Cycle
- 10000 pages
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x maintenance cartridge (black) - up to 500 pages
- ISO 9001, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 250 Watt
- Power Consumption Stand by / Sleep
- 5 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 40.2 cm
- 36.85 cm
- 11.9 cm
- 6.2 kg
