ADAPT AND UNLEASH
Designed to dominate in MMO, Battle Royale, FPS, and more, the multi-genre master returns stronger than ever. With 3 swappable side plates, 19+1 programmable buttons, a Razer HyperScroll Pro Wheel, and Razer HyperSpeed Wireless, the Razer Naga V2 Pro packs the power to rise above every genre.
ABSOLUTE ADAPTABILITY AND CONTROL
3 Swappable Side Plates for Up To 22 Programmable Controls
The Razer Naga V2 Pro comes with a set of 12, 6 and 2-button magnetic side plates, allowing you adapt to any game genre with up to 22 programmable controls.
RAZER™ HYPERSCROLL PRO WHEEL
Unlimited Configuration and Scroll Feel
Toggle between 5 presets and 1 custom mode all at the tap of a button.
FULLY CUSTOMIZABLE SCROLL FEEL
With adjustable tactility, resistance, and steps, create firmer, more distinct scrolls for precise weapon switching, or softer, smoother scrolls with multiple steps to easily spam inputs like jump.
From a scale of 0 to 100, adjust the strength required for each tick of the scroll wheel. The lower the number, the easier it is to scroll—with 0 providing a completely smooth scroll feel. From a scale of 0 to 100, adjust the strength required for each tick of the scroll wheel. The lower the number, the easier it is to scroll—with 0 providing a completely smooth scroll feel.
3 MODES OF CONNECTIVITY
Lasts up to 150 hours on HyperSpeed, 300 hours on Bluetooth, and can be connected via USB Type C for continued use while charging.
RAZER™ FOCUS PRO 30K OPTICAL SENSOR
Razer’s industry leading sensor provides flawless tracking performance on a wider variety of surfaces including glass—supported by intelligent functions for enhanced aim and control.
RAZER™ OPTICAL MOUSE SWITCHES GEN-3 From an improved 90-million click lifecycle with zero double-clicking issues, to a blistering 0.2ms actuation with no debounce delay, enjoy reliability and speed that outshines all others.
Absolute adaptability and control
The Razer Naga V2 Pro comes with a set of 12, 6 and 2-button magnetic side plates, allowing you adapt to any game genre with up to 22 programmable controls. -
Fully customizable scroll feel
With adjustable tactility, resistance, and steps, create firmer, more distinct scrolls for precise weapon switching, or softer, smoother scrolls with multiple steps to easily spam inputs like jump. -
High-performance, low-latency gaming
Enjoy ultra-responsive gaming with a connection faster than other wireless tech. Streamline your setup and free up a USB port by connecting your wireless mouse and keyboard to a single dongle - a feature that can be activated in Razer HyperSpeed peripherals. -
3 modes of connectivity
Lasts up to 150 hours on HyperSpeed, 300 hours on Bluetooth, and can be connected via USB Type C for continued use while charging. -
30K optical sensor
Razer's sensor provides flawless tracking performance on a wider variety of surfaces including glass - supported by intelligent functions for enhanced aim and control.
- Razer Naga V2 Pro - mouse - MMO, HyperScroll Pro wheel, gaming - Bluetooth, 2.4 GHz, USB-C
- Mouse - ergonomic
- Connectivity Technology
- Wireless, wired - Bluetooth, 2.4 GHz, USB-C
- Orientation
- Right-handed
- 7.55 cm x 11.95 cm x 4.35 cm
- 134 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 20
- Movement Resolution
- 30000 dpi
- Performance
- 70 G maximum acceleration, 750 inches per second
- Gaming
- 5 profiles, Razer Synapse 3 enabled, tiltable scroll wheel, wireless charging, Razer Speedflex Cable, Razer Chroma RGB, Razer Hyperspeed Wireless technology, 3 swappable side plates, Razer HyperScroll technology, on-board memory profile, Focus Pro optical sensor, PTFE mouse feet, Razer 3rd-gen optical mouse switch, 90 million clicks
- 2-year warranty
- Mouse
- Ergonomic Design
- Orientation
- Right-handed
- Gaming
- 7.55 cm
- 11.95 cm
- 4.35 cm
- 134 g
Input Device
- Wireless, wired
- Interface
- Optical
- Buttons Qty
- 20
- 30000 dpi
- Performance
- EN 62479:2010, Directive 2014/30/EU, IEC 62368-1, Directive 2014/53/EU, REACH 2006/1907, 2011/65/EU, EN 50663:2017, ETSI EN 301 489-1 V2.2.1 (2019-03), EN 301 489-1 V2.2.3, EN55035:2017+A11:2020, EN 55032:2015+A1:2020
- Run Time (Up To)
- 300 hour(s)
- Software Included
- Razer Synapse 3
- Limited warranty - 2 years
