Enter a new dimension of deadly with the Razer Huntsman Mini - a 60% gaming keyboard with cutting-edge Razer Optical Switches. Highly portable and ideal for streamlined setups, it's time to experience lightning-fast actuation in a compact form factor.
Razer clicky optical switches
The go-to choice for gamers who prefer receiving crisp, tactile feedback that sounds as satisfying as it feels. -
Improved Razer linear optical switches
Delivering smooth, instant keystrokes with no tactile bump, this 2nd-gen design sports significant enhancements to the acoustics of the switch with sound dampeners to reduce noise as you bottom out your keys. -
Doubleshot PBT keycaps with side-printed secondary functions
Designed for greater durability, the keycaps on this 60% gaming keyboard have a premium, textured quality that'll never degrade to a shiny finish or have their labeling wear off with intense use. For easier reference when executing commands and hotkeys, side-printed secondary functions have also been added. -
Onboard memory and lighting presets
Take your settings anywhere as you store and activate up to five keyboard profiles without the need for software, and personalize it further with a preloaded suite of Razer Chroma RGB lighting effects.
- Razer Huntsman Mini - keyboard - QWERTY - UK - black
- Keyboard
- Backlit
- RGB Chroma
- Interface
- USB-C
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Multimedia, programmable
- Key Switch Type
- Razer Clicky Optical Purple
- Black
- 2-year warranty
- Keyboard
- Backlit
- RGB Chroma
- Interface
- USB-C
Input Device
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Optical
- Key Switch Type
- Adjustable Height
- Detachable Cable
- Black
- Limited warranty - 2 years
