Razer Enki Green Gaming Chair
Quicklinx: HL7RWS00 Mfr#: RZ38-03720100-R3G1
Type: Gaming Chair
£308.33 ex VAT
£369.99 inc VAT
Fully sculpted lumbar support
Multi-layered synthetic leather
High density foam cushions
Razer Enki - chair - high-density polyurethane molded foam, elastomeric polyurethane (EPU), steel frame, aluminium base - black, green
Chair - armrests - T-shaped - tilt - swivel
Gaming
Headrest
Casters
Lumbar Support
Material
High-density polyurethane molded foam, elastomeric polyurethane (EPU), steel frame, aluminium base
Black, green
67 cm
68 cm
131 cm - 141 cm
24.1 kg
3 years
Chair - armrests - tilt - swivel
Gaming
Headrest
Armrest Qty
2
Casters
Max Load Weight
136 kg
Max User Height
204 cm
Material
Black, green
Class 4 gas lift
Seat
Foam padded
Backrest
Angle Adjustment
Lumbar Support
Foam padded, 152° adjustable angle
Base
Design
5-pointed star
Casters
5 x 6 cm
Material
Steel frame, aluminium base
Polyurethane (PU) casters
Armrests
Shape
T-shaped
Adjustable Armrests
4D adjustable
Headrest
Adjustable Headrest
No
67 cm
68 cm
131 cm - 141 cm
24.1 kg
3 years
Type: Gaming Chair
Brand: Razer
