Designed for simple and reliable backups, the SuperLoader 3 offers an exclusive package of advanced features including StorageCare Guardian, remote management, and barcode reader - all at no additional cost. It also gives you the widest range of drive options in the industry to support data requirements up to 100TB - with the flexibility to expand as your storage needs grow.
The SuperLoader 3 brings you a full suite of advanced features at an affordable price with easy integration, an intuitive user interface, and compatibility with a broad range of backup software packages. And because you can easily expand from 8 to 16 cartridge slots, your investment is protected as your needs grow. In addition, the SuperLoader 3 packs up to 40TB of native capacity and 100TB of compressed data into a 2U rackmount form factor.
- Quantum SuperLoader 3 - tape autoloader - LTO Ultrium - SAS-2
- Tape autoloader
- Recording Standard
- LTO Ultrium 5
- Enclosure Type
- Rack-mountable - 2U
- Interface Type
- SAS-2
- Total Storage Capacity
- 24 TB (native) / 48 TB (compressed)
- Removable Media Capacity
- 16
- Supported Tape Drives
- LTO Ultrium 5
- Key Features
- Barcode reader
- 42.4 cm x 69.9 cm x 8.7 cm
- 14.1 kg
- Localisation
- EMEA
- Storage Removable
- LTO Ultrium
- Storage Removable Capacity
- 1.5 TB (native) / 3 TB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 4, Ultrium 5
- Data Transfer Rate (native)
- 140 MBps (504 GBph)
- Data Transfer Rate (compressed)
- 280 MBps (1.008 TBph)
- Power
- AC 120/230 V (50/60 Hz)
- 3-year warranty
- Tape autoloader - LTO Ultrium
- LTO Ultrium 5
- Enclosure Type
- Interface Type
- SAS-2
- 16
- LTO Ultrium 5
- Key Features
- Barcode reader
- Built-in Devices
- Display
- 42.4 cm
- 69.9 cm
- 8.7 cm
- 14.1 kg
- Localisation
- EMEA
Storage Removable
- LTO Ultrium
- Capacity
- 1 x SAS-2 - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088) , 1 x Ethernet 10Base-T/100Base-TX (management) - RJ-45
- Included Accessories
- 5 barcode labels for cleaning cartridges, 30 barcode labels
- Cables Included
- 1 x SAS cable - 2 m , 1 x network cable - 3.1 m
- Rack Mounting Kit
- Included
- CSA, UL, VCCI, C-Tick, VCCI Class B ITE, BSMI CNS 13438 Class A, EN 60950, EN55022, ICES-003, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, AS/NZS 3548, FCC, FCC CFR47 Part 15 B
- Power supply
- Voltage Required
- Limited warranty - parts - 3 years - shipment - response time: 2 business days
- 10 °C
- 35 °C
- 20 - 80%
