Quantum's LTO-4 HH SCSI tape drive is a half-height tape drive that offers high capacity, 1.6TB (2:1 compressed) and performance, 576GB/hr (2:1 compressed), all in a space saving and energy efficient half-height format. Quantum's LTO-4HH SCSI tape drive also provides native AES 256-bit hardware data encryption, providing easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. By using LTO-4 encryption, not only is data fully capable of being compressed therefore maximizing capacity, encrypted backups are completed without a loss in performance.
Quantum's LTO-4 HH tape drives protect your investment by providing backward read and write compatibility with LTO-3 media and backward read compatibility with LTO-2 media. With ultimate reliability and ease of use in mind, even at a 100% duty cycle, Quantum's rugged design builds on superior LTO technology and adds advanced features to create a new level of data protection. Quantum's LTO 4HH SCSI tape drives employ dynamic data rate matching to adjust to the speed of the host, reducing wear and tear on both drive and media and increasing performance, even on slower hosts. The drive also features an ultra-durable soft-load feature that automatically positions the data cartridge, and the highly reliable leader-capture mechanism virtually eliminates lost leaders, increasing the success of your backup and restore operations.
- Quantum LTO-4 HH - tape drive - LTO Ultrium - SCSI
- Tape drive
- Recording Standard
- LTO Ultrium 4
- Enclosure Type
- External
- Interface Type
- SCSI LVD
- 21.2 cm x 27.2 cm x 6.6 cm
- 3.6 kg
- Black
- Storage Removable
- LTO Ultrium
- Storage Removable Capacity
- 800 GB (native) / 1.6 TB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 3, Ultrium 4
- Data Transfer Rate (native)
- 80 MBps (288 GBph)
- Data Transfer Rate (compressed)
- 160 MBps (576 GBph)
- Power
- AC 120/230 V (50/60 Hz)
- OS Required
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Vista
- Microsoft Certification
- Works with Windows Vista
- 3-year warranty
- Tape drive - LTO Ultrium
- LTO Ultrium 4
- Enclosure Type
- External
- Interface Type
- SCSI LVD
- Built-in Devices
- Led panel
- Enclosure Colour
- Black
- 21.2 cm
- 27.2 cm
- 6.6 cm
- 3.6 kg
Storage Removable
- LTO Ultrium
- Capacity
- Average Seek / Access Time
- 70 sec
- Buffer Size
- 128 MB
- 1 x Ultra320 SCSI LVD - 68 pin HD D-Sub (HD-68)
- Media Included Qty
- 1
- Included Accessories
- Cleaning cartridge
- Cables Included
- 1 x SCSI cable - 2.5 m , 1 x SCSI terminator
- MTBF
- 250,000 hour(s)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- CSA, UL, VCCI, BSMI, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, EMC, MIC, AS/NZS 3548, SII, UL 60950-1, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 B, BSMI CNS 14336, CSA C22.2 No. 60950-1
- Power supply
- Voltage Required
- 20 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - parts - 3 years - shipment - response time: 2 business days
- 10 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 52 dBA
