Quantum's LTO-3 HH tape drive provides the fastest native transfer rate of any half-height drive. Its simple half-height form factor allows easy installation and integration into your datacenter. The LTO-3 HH tape drive is backward read and write compatible with LTO-2 media and backward read compatible with LTO-1 media. All with Quantum's exclusive reliability features including: SmartVerify virtually eliminating the need for a traditional verify pass during backup, reducing the backup window and increasing data integrity; FastSense matching tape drive speed to that of the host, optimizing performance and increasing reliability; Dynamic PowerDown protecting the tape drive and data cartridge during unexpected power loss.
- Quantum LTO-3 HH - tape drive - LTO Ultrium - SCSI
- Tape drive
- Recording Standard
- LTO Ultrium 3
- Enclosure Type
- External
- Interface Type
- SCSI LVD
- 21.2 cm x 27.2 cm x 6.6 cm
- 3.6 kg
- Black
- Storage Removable
- LTO Ultrium
- Storage Removable Capacity
- 400 GB (native) / 800 GB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 2, Ultrium 3
- Data Transfer Rate (native)
- 68 MBps (245 GBph)
- Data Transfer Rate (compressed)
- 136 MBps (490 GBph)
- Power
- AC 120/230 V (50/60 Hz)
- OS Required
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Vista
- 3-year warranty
- Tape drive - LTO Ultrium
- LTO Ultrium 3
- Enclosure Type
- External
- Interface Type
- SCSI LVD
- Built-in Devices
- Led panel
- Enclosure Colour
- Black
- 21.2 cm
- 27.2 cm
- 6.6 cm
- 3.6 kg
Storage Removable
- LTO Ultrium
- Capacity
- Average Seek / Access Time
- 60 sec
- Buffer Size
- 128 MB
- 1 x Ultra320 SCSI LVD (input) - 68 pin HD D-Sub (HD-68) , 1 x Ultra320 SCSI LVD (output) - 68 pin HD D-Sub (HD-68)
- Media Included Qty
- 1
- Included Accessories
- Cleaning cartridge
- Cables Included
- 1 x SCSI cable - 2.5 m
- MTBF
- 250,000 hour(s)
- CSA, UL, VCCI, BSMI, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, EMC, MIC, AS/NZS 3548, SII, UL 60950-1, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 B, BSMI CNS 14336, CSA C22.2 No. 60950-1
- Power supply
- Voltage Required
- 28 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - parts - 3 years - shipment - response time: 2 business days
- 10 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 52 dBA
