When expanding data storage capacity, deploying multiple servers can lead to complexity in management and dramatically increased cost. The QNAP UX-800P expansion enclosure is a budget-friendly expansion alternative designed with easy setup in mind for expanding the total storage space of your Turbo NAS for general applications. By connecting one expansion enclosure, the UX-800P offers a hassle-free storage expansion for home/small office use.
Easily add additional drive capacity to a Turbo NAS
Simply connect the UX-800P to a Turbo NAS and power it on. The Turbo NAS will automatically detect the hard drives in the UX-800P as newly installed local drives. The Turbo NAS capacity can then be expanded as a large volume seamlessly and economically by using the powerful QTS Storage Manager. -
Missing mode protection
If your UX-800P is accidentally disconnected, the Turbo NAS enters missing mode and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data staying intact. -
Powerful QTS storage manager
The QTS storage manager neatly presents tools and options for managing system storage with a modern & intuitive graphical user interface, which greatly simplifies the process of NAS capacity expansion and UX-800P management. No matter if you are an IT administrator or Home user, you can easily monitor the health status of UX-800P and the disks within it. When multiple expansion enclosures are connected, the Locate Disk and Locate Enclosure functions assist you in quick maintenance. -
Flexible RAID Configuration
The UX-800P features 8 hot-swap drive bays for easy installation and removal. The automatic insertion/removable detection and rebuild allow easy management. Featuring RAID 0, 1, 5, 6 and 10 supports and managed by the powerful QTS storage manager, the UX-800P ensures maximum performance and data security. -
An excellent backup solution for Turbo NAS
The UX-800P can be used as a budget-friendly external storage to perform speedy and secure backup tasks for the Turbo NAS. The administrator can back up the Turbo NAS data to the UX-800P on a real time or scheduled basis. -
Smart power design
The UX-800P automatically powers on and off with your Turbo NAS, allowing for total convenience and energy saving. -
Excellent hardware design
The UX-800P includes a full 350W internal PSU to provide ample power even under sustained full load. The well-ventilated chassis and smart fan helps to provide efficient cooling for better stability and reliability, with the fan enabling efficient heat removal even when all 8 drives are under full operation simultaneously.
- QNAP UX-800P - hard drive array
- Hard drive array
- Total Array Capacity
- 32 TB
- Interface
- USB 3.0
- Installed Devices / Modules Qty
- 8 (installed) / 8 (max)
- Supported Drives
- SATA-600
- Built-in Devices
- Status LCD, led panel
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- 8 x 4 TB HDD SATA 6Gb/s - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- Hard drive array
Chassis
- Built-in Devices
- 8
- Supported Devices / Modules Qty
- 8
- Supported Drives
- SATA-600
Storage
- 32 TB
- HDD Array External Interface
- USB 3.0
Storage Controller
- SATA
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
Hard Drive
- HDD - hot-swap
- Capacity
- 8 x 4 TB
- Interface Type
- SATA 6Gb/s
- Expansion Bays
- 8 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
- 1 x USB 3.0 - 9 pin USB Type B
- Security lock slot (cable lock sold separately), built-in 2 cooling fans
- Cables Included
- 1 x USB 3.0 cable
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 350 Watt
- 5 °C
- 35 °C
- 5 - 95% (non-condensing)
