QNAP TS-453 Pro 2GB 4 Bay NAS
Quicklinx: 9XG5WS00 Mfr#: TS-453 PRO-2G
  • Celeron
The TS-453 Pro, featuring the easy-to-use QTS operating system, is a powerful, reliable, secure and scalable NAS solution designed for mission-critical business applications and to meet fast growing data storage needs. The TS-453 Pro supports SATA 6Gb/s drives and delivers high performance with persistent throughput, providing a comprehensive storage solution for SMBs to build a reliable private cloud.
  • Use the TS-453 Pro as a PC with exclusive QvPC Technology
  • Manage, share, and back up business data with Real-time Remote Replication (RTRR)
  • NAS and iSCSI-SAN unified storage solution for server virtualization
  • Supports VMware®, Citrix®, and Microsoft® Hyper-V and advanced virtualization features
  • Enhanced data security with high-performance AES 256-bit encryption and anti-virus
  • Run multiple Windows/Linux-based virtual machines with the Virtualization Station
  • Transcode Full HD videos on-the-fly or offline with QNAP's unique transcoding technology
  • Expand the total raw storage capacity up to 72TB with the economical UX-800P QNAP expansion enclosure
Powered by a cutting-edge 22nm quad-core Intel® Celeron® 2.0GHz processor with 2GB/8GB energy-efficient DDR3L RAM (upgradable to 8GB), coupled with the support of SATA 6Gb/s, 4 Gigabit LAN ports and HDMI output, the TS-453 Pro is a powerful NAS that delivers up to 415MB/s read & write speeds. The TS-453 Pro can also automatically increase the processor's clock rate from 2.0GHz to 2.41GHz when needed for CPU-intensive tasks. The TS-453 Pro's fast encryption and decryption performance provides transfer speeds of up to 70MB/s with AES-256 bit volume encryption, boosting system performance & security while ensuring the safety of sensitive business data stored in the TS-453 Pro. When installed with the latest dual-band 2.4GHz/5GHz 802.11ac Wi-Fi network card, the TS-453 Pro can offer remarkably high speeds for transferring large amount of files and streaming bandwidth-consuming multimedia.
  • Reduces physical server maintenance
    Compared with dealing with physical servers which are less resource-consuming but need to be present, it is more cost-efficient to use the Virtualization Station to manage those servers on the virtual machines on the Turbo NAS. It not only increases the efficiency of IT management, but also reduces management costs and room for physical servers.
  • Bandwidth-saving and secure to access NAS data
    When accessing data on the Turbo NAS through the virtual machines on the Virtualization Station, you can enjoy the secure data transmission and bandwidth saving, as the data is not transmitted via physical network cables.
QNAP TS-453 Pro - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 4 (max)
18 cm x 23.5 cm x 17.7 cm
3.65 kg ()
1 x Intel Celeron 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
24
RAM
2 GB
UNIX, Linux, Microsoft Windows XP or later, Apple MacOS X or later, Microsoft Windows Server 2003 or later
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
18 cm
23.5 cm
17.7 cm
3.65 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, proxy server, web server, backup server, download client, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, surveillance station, DLNA Media Server, DHCP client, e-mail notification, cloud backup, VPN Server, Apple AirPlay
Encryption Algorithm
FIPS 140-2, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
24
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x HDMI output - Type A
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
Security Slot Type
Kensington security slot
Internal power supply
33.13 Watt
Power Provided
250 Watt
5 - 95% (non-condensing)
