The TS-253 Pro is a powerful, reliable, secure and scalable NAS solution designed for mission-critical business applications and to meet fast growing data storage needs. The TS-253 Pro supports SATA 6Gb/s drives and delivers high performance with persistent throughput, providing a comprehensive storage solution for SMBs to build a reliable private cloud.
High performance
Powered by a powerful processor with energy-efficient DDR3L RAM, coupled with the support of SATA 6Gb/s, 2 Gigabit LAN ports and HDMI output, the TS-253 Pro is a powerful NAS that delivers up to 415MB/s read & write speeds. The TS-253 Pro can also automatically increase the processor's clock rate from 2.0GHz to 2.41GHz when needed for CPU-intensive tasks. The TS-253 Pro's fast encryption and decryption performance provides transfer speeds of up to 70MB/s with AES-256 bit volume encryption, boosting system performance & security while ensuring the safety of sensitive business data stored in the TS-253 Pro. -
Simple and efficient
Thanks to the intuitive user interface of QTS, system operations of the TS-253 Pro are smooth and handy. Its intelligent desktop allows you to find desired functions quickly, create desktop shortcuts or group shortcuts, monitor important system information on a real-time basis, and open multiple application windows to run multiple tasks concurrently, bringing greater operating efficiency. -
Run additional operating systems on the TS-253 Pro
With the support for Intel Virtualization Technology (VT-x), the TS-253 Pro can operate the Virtualization Station, transforming the TS-253 Pro into a 2-in-a-box NAS that can function as an all-in-one NAS and a virtualization platform that supports multiple operating systems, fast virtual machine (VM) creation, VM import/export, snapshot, and enables desktop operations on web browsers. With the easy-to-use interface, you can centrally manage all of the VMs created on the TS-253 Pro with minimal effort. You can also download VMs on demand from online VM markets and import them to the TS-253 Pro without any complex procedures. -
Comprehensive security options
In open network environments, business data may be exposed in a potential hack. The TS-253 Pro provides numerous security options, such as encrypted access, IP blocking, and more. IT administrators can also control the access rights of each user to different folders, preventing unauthorized access to important files. The TS-253 Pro is validated with military-level FIPS 140-2 AES 256-bit encryption, preventing sensitive business data from unauthorized access and breach even if the hard drives or the entire system were stolen. -
Full HD videos local display with HD Station via HDMI
QNAP HD Station integrates the powerful XBMC v12 media player and web browser. With HDMI 1.4a connectivity, you can connect the TS-253 Pro to a HDTV to enjoy your multimedia on the big screen. The splendid user interface and support for 7.1-surround sound passthrough brings smooth playback of Full HD 1080p videos. -
File synchronization across multiple devices
The Qsync utility turns your TS-253 Pro into a safe data center for file synchronization with a large storage capacity. Any file uploaded to the TS-253 Pro will be made available for all linked devices, such as computers, laptops or mobile devices. Qsync is especially useful for frequent travelers to manage files and always have updated files on different devices. Qsync provides multiple ways of file synchronization and group file sharing, greatly enhancing the flexibility of collaboration. -
Creatively present your animated content and ads
With the Signage Station, it is easy to create content for a wide range of materials such as menu boards, advertisements, posters, and business profiles. The Signage Station is a great tool to invigorate your advertisements or animated materials for promoting your services, and to update contents in a timely manner. The iArtist Lite application, with intuitive editing tools, helps you create these signs with simple drag & drop tools. Your creativity can now travel around the world with a few simple steps to instantly get published, revised, and shared. -
Energy-saving
The TS-253 Pro features low voltage requirements and low power consumption whilst maintaining high performance in system operations. Other eco-friendly designs include S3 sleep mode, scheduled power on/off, hard disk standby mode, and Wake on LAN.
- QNAP TS-253 Pro - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 10.2 cm x 21.6 cm x 15 cm
- 1.74 kg ()
- Processor
- 1 x Intel Celeron 2 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 1 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 24
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- UNIX, Linux, Microsoft Windows XP or later, Apple MacOS X or later, Microsoft Windows Server 2003 or later
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 10.2 cm
- 21.6 cm
- 15 cm
- 1.74 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 8 GB (supported) - DDR3L
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 1 TB
- Data Link Protocol
- TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, proxy server, web server, backup server, download client, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, surveillance station, DLNA Media Server, DHCP client, e-mail notification, cloud backup, VPN Server, Apple AirPlay
- Encryption Algorithm
- FIPS 140-2, 256-bit AES
- DLNA CERTIFIED, UPnP
Security DVR
- 24
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x HDMI output - Type A
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan
- Security Slot Type
- Kensington security slot
- Power Device
- External power adapter
- Voltage Required
- 16.34 Watt
- Power Provided
- 90 Watt
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
