Manufactured from 2mm steel the Pi server range can accommodate all of today's data centre requirements and this additional grade of material allows a static loading of 750kgs to be used. This range of enclosures can be supplied with a choice of cladding options including mesh single piece, mesh wardrobe or glass doors.
- Width: 800mm
- Height: 42u
- Depth: 1000mm
- Type: Server Cabinet
The internal mounting profiles have been designed to accommodate all of today's server manufacturers products and with the use of the mid profiles supplied and number of different depths of products can be accommodated within the one enclosure.
- Data Centres / Comms rooms
- 19" Server Equipment Housing
- Communication Systems
- Structured cabling / multi vendor installations
- Enclosed glass front door with mesh surround
- Lever latch lock with 3 point locking system
- Lockable rear metal door with 64% airflow mesh
- Lockable side panels with high and low level venting
- Raised and vented top cover with cable entry
- Open base design
- Vertical cable management (800mm wide only)
- Fully adjustable 'vendor neutral' 19" mounting profiles
- Mid style multiple depth mounting profiles
- Earth bonding kit Full range of complenting accessories
- Transport castors
- Supplied assembled or in flat pack option
- Multiple door configurations available
- Configurable roof options to cater for overhead cable installations
- Open base design with plate options to maintain security
- Full range of airflow management accessories
- High density power and cooling options
- Product Reference: CAB42810-SVR
