POLYCOM EXT MICS (2) SOUNDSTATION 2EX
Quicklinx: 74MHWS00 Mfr#: 2200-16155-015
How do you make industry-leading products even better? By adding Polycom's convenient and easy-to-use accessories that help you to save time, be more productive, and add more enjoyment to the use of your conferencing products. Whether it's cables, headsets, or a protective carrying case for your voice conferencing products, Polycom makes it easy for you to find the accessories you need.
Poly - microphone
Microphone
Packaged Quantity
2 (specifications are for single item)
Recommended Use
Conference
Microphone
External
Controls
Mute
Packaged Quantity
Microphone
Recommended Use
Conference
Microphone
Wired
Remote Control
Controls
Mute
Cable Details
Microphone cable
