Working in and out of the office? We've got you covered. The Voyager 5200 headset provides professional-grade sound, no matter where you take the call. Now you can thrive in any environment on any of your devices, with versatile connectivity and Bluetooth technology.
Four-mic noise cancelling
Cutting edge noise cancelling technology eliminates background noise, so your voice always sounds clear. Four-mic array and our adaptive Digital Signal Processors (DSP) work together to cancel disruptive background noise like traffic or crowds. -
Take the call anywhere
Six layers of our unique WindSmart technology detect wind direction and respond accordingly so your voice comes through clearly – especially outdoors. -
High-quality audio
Supports HD Voice over wideband networks and devices to enhance speech quality, so your caller clearly hears and understands you. -
Smart sensor technology
Smart sensors know when the headset is on or off; calls can be easily answered by simply putting on the headset; pause music for incoming calls, or mute a call by taking the headset off. -
Manage your calls using voice commands
Announces the names of incoming callers and waits for you to say "Answer" or "Ignore", allowing you to manage your calls using voice commands.
- Poly Voyager 5200 - headset
- Product Type
- Headset - Bluetooth - wireless, wired - USB-A via Bluetooth adapter
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- In-ear monaural
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Audio Specifications
- Frequency Response 100 - 20000 Hz - Sensitivity 90 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional, MEMS-directional
- Microphone Noise Cancelling
- Controls
- Mute, volume control, on/off
- Product Type
- 9.1 cm
- 5.3 cm
- 1.5 cm
- 20 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- Voice alerts
Audio Output
- In-ear monaural
- Wireless, wired
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Equaliser
- 20 bands
- 100 - 20000 Hz
- Sensitivity
- 90 dB
- Impedance
- 32 Ohm
- Diaphragm
- 13.6 mm
- Smart Sensor Technology, digital signal processing, echo cancelation
Microphone
- Boom
- Sensitivity
- -38 dBV/Pascal
- 100 - 6800 Hz
- Noise Cancelling
Remote Control
- Controls
- Included Accessories
- Charging case, 3 ear tips (small, medium, large), micro-USB charging cable, BT700 Bluetooth USB adapter
- Battery
- Headset battery rechargeable - lithium polymer
- Capacity
- 122 mAh
- Run Time (Up To)
- 7 hours
- Standby Time
- 9 days
- Recharge Time
- 1.6 hours
