Experience unparalleled collaboration with advanced video capabilities, superior audio quality, and effortless setup. Enhance productivity, foster inclusivity, and create better connections. Transform the way you work, collaborate, and communicate.
Never miss a moment
Poly DirectorAI smart camera framing works behind the scenes to keep you framed how you want-whether that's switching between people speaking, following a presenter, or a close up view of everyone in the room. Keep everyone engaged and involved. -
Impeccable noise reduction
Poly NoiseBlock AI and Acoustic Fence Technologies reduce background noise and provide an interference-free audio experience. Minimize distractions, such as keyboard typing, or nearby conversations so you can focus on collaboration. -
Quick and effortless setup
Swiftly set up your Poly Studio R30: just two cords are needed. Plug in the power and connect your PC via USB and you are ready to go. Remember you may want to connect your PC to the monitor, which would require a separate HMDI cable. -
Clear resolution
Say goodbye to grainy, blurry videos that make it hard to focus and connect. Our stunning 4K resolution, provides you with lifelike visuals that capture every expression, gesture, and nuance for a truly engaging meeting experience. -
Bring everyone together
Gather the team without feeling cramped. The impressive 120-degree field of view allows everyone to be seen. This wide angle eliminates the need for camera adjustments or awkward seating arrangements, making it perfect for small meeting spaces. -
Rich voice clarity
The powerful integrated speaker delivers rich, crystal-clear audio, enabling participants to hear every word with clarity. The advanced speaker ensures that even the softest-spoken voice is amplified, making meetings more productive.
- Poly Studio R30
- USB video bar
- 44.5 cm x 8.1 cm x 6.8 cm
- 737 g
- Localisation
- English / United Kingdom
- Video Input
- Digital camera - SuperSpeed USB 3.0
- Audio Input
- 3-microphone array - beamforming
- Audio Output
- Speaker(s)
- Networking
- Network adapter - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Software Certification
- Zoom Certified, Certified for Microsoft Teams
- System Requirements
- Windows 8.1, Windows 10, Windows 11, Apple macOS 10.10 or later
- 1-year warranty
- USB video bar
- 44.5 cm
- 8.1 cm
- 6.8 cm
- 737 g
- Dimensions & Weight Details
- Video bar - Width 44.5 cm Depth 8.1 cm Height 6.8 cm Weight 737 g , Video bar (with monitor clamp) - Width 44.5 cm Depth 8.1 cm Height 8.6 cm Weight 822 g
- Built-in Devices
- Speaker, camera, 3 microphone beam forming array
- Enclosure Colour
- Sand
- Localisation
Video Input
- Digital camera - integrated
- Interface Type
- Digital Video Capture Resolution
- 1280 x 720, 1920 x 1080, 3840 x 2160, 720p, 1080p, 2160p
- Digital Zoom
- 5
- 120° diagonal field of view, 110° field of view (horizontal), UHD 2160p (4K) capture resolution, speaker tracking, automatic people framing, Poly NoiseBlockAI technology, Poly Acoustic Fence technology, Poly DirectorAI technology, Poly Acoustic Clarity technology, Conversation Mode, security slot (Kensington security lock compatible)
Audio Input
- 3-microphone array - internal
- Microphone Operation Mode
- Beamforming
Audio Output
- Speaker(s)
- Network adapter
- Connectivity Technology
- Wireless
- Data Link Protocol
- IEEE 802.1x
- 1 x USB-C - 24 pin USB-C , 2 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB-C to USB-A cable , 1 x power cable
- Included Accessories
- Monitor clamp, removable privacy cap
- Plug and Play
- Power Device
- Power adapter - external
- Software Included
- Poly Lens management software
- OS Required
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 15 - 80%
