Poly Blackwire 5220 C5220 USB-C Headset
Quicklinx: HM3DWS00 Mfr#: 805H3AA
Recommended Use: Computer, Portable electronics
Connectivity: Wired
Earcover : Monaural
More than 50 In Stock
£68.92 ex VAT
£82.70 inc VAT
The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
  • Connectivity options
    Select the right option for your device: USB-A or USB Type-C for PC and 3.5 mm for mobile connectivity.
  • Comfort and durability
    Ultra-soft leatherette ear cushion(s) wrapped around pillow-soft memory foam provide long lasting comfort. A lightweight cushioned metal headband offers durability and a comfortable custom fit.
  • Wearing style
    Hi-fi stereo wearing style for those who want a richer, more immersive experience.
  • Simple call management
    Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status.
  • Outstanding audio quality
    Premium PC wideband audio with noise-canceling microphone and Digital Signal Processing (DSP) for a more natural voice sound.
  • Enhanced call quality
    Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
Poly Blackwire C5220 - headset
Headset - wired - 3.5 mm jack, USB-C
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 90 dB
Impedance
32 Ohm
Microphone
Boom
Controls
Mute, volume, answer/end
Software Certification
Certified for Skype for Business, Certified for Microsoft Teams, Avaya Certified, Cisco Jabber Certified
Series
Blackwire 5200 series
Compatibility
Mac, Windows
164.2 g
Earpad Material
Artificial leather
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
Digital signal processing, Dynamic EQ optimised
Microphone
Boom
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
Carrying case
Supported Host Device OS
macOS, Windows
HM3D Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.42
HM3D Poly Headset Splitter - Y-type training cable for Poly EncorePro In Stock £24.71
HM3D Poly Audio Cable - M22 to Quick Disconnect for Poly EncorePro In Stock £10.99
HM3D Poly DA75 Sound Card In Stock £32.13
HM3D Poly Headset Cable - M22 to Quick Disconnect for Poly M22 In Stock £10.64
HM3D Poly Spare Ear Cushion Foam for C310 & C320 In Stock £2.82
HM3D Poly HIS Adapter Cable In Stock £24.71
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Monaural
Brand: Poly
