PNY Quadro NVS 450 512MB PCI-E x16
Quicklinx: 64D8WS00 Mfr#: VCQ450NVS-X16-PB
  • DisplayPort
NVIDIA Quadro NVS 450 by PNY delivers a reliable hardware and software platform for a stable environment and robust IT management tools for seamless enterprise deployment. Featuring NVIDIA nView multi-display technology and support for up to four displays, business professionals can maximize productivity through increased desktop real estate and advanced application management tools. Quadro NVS 450 is certified on leading business applications and designed to meet the needs of today's most demanding business user.
Quadro NVS 450 is the chosen solution across mixed environments, including financial institutions, emergency call centers, digital signage systems, and other mission-critical environments.
Featuring CUDA parallel computing processors with a unified architecture designed to dynamically allocate GPU resources, the Quadro NVS 450 solution delivers optimized performance for business graphics. Capable of supporting up to four digital displays at resolutions of up to 2560 x 1600 each through the DisplayPort connectors, the Quadro NVS 450 maximized productivity by enabling more screen real estate from a single graphics card.
Through the NVIDIA nView advanced display software, Quadro NVS 450 enables features such as profiles, extended Windows taskbar, gridlines, and virtual desktops. In addition, Quadro NVS 450 provides high-quality HD video output and high memory bandwidth for today's more demanding digital signage requirements.
  • NVIDIA unified GPU architecture
    Industry's first unified architecture designed to dynamically allocate GPU resources to deliver optimized performance.
  • NVIDIA CUDA parallel computing processor
    16 CUDA parallel processing cores compatible with all CUDA accelerated applications, NVIDIA CUDA provides a C language environment and tool suite that unleashes capabilities to solve various visualization challenges.
  • Quad DisplayPort
    Featuring the small and user friendly DisplayPort connectors, Quadro NVS 450 is capable of supporting quad high-resolution displays at 2560 x 1600 resolution.
  • Fanless design
    It built with a passive heatsink for a quieter desktop environment.
  • NVIDIA PureVideo technology
    NVIDIA PureVideo technology is the combination of high-definition video processors and software that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content. Features include high-quality scaling, spatial temporal de-interlacing, inverse telecine and high quality HF video playback from DVD.
  • Energy Star enabled design
    It enables Energy Star compliance with low maximum and low idle power levels.
NVIDIA Quadro NVS 450 by PNY - graphics card - 2 GPUs - Quadro NVS 450 - 512 MB
Graphics card
Bus Type
PCI Express x16
Graphics Engine
2 GPUs - NVIDIA Quadro NVS 450 - up to
512 MB GDDR3
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Monitors Supported
4
Interfaces Details
4 x DisplayPort
16.8 cm x 11.1 cm
3-year warranty
Graphics card
Bus Type
PCI Express x16
Graphics Engine
Max Resolution
2560 x 1600
4
Interfaces Details
4 x DisplayPort
Fanless heatsink, Nvidia CUDA technology, Nvidia PureVideo HD technology
Size
512 MB
GDDR3 SDRAM
Bus Width
128-bit
Linux, Microsoft Windows NT 4.0 SP6, Microsoft Windows 2000 / XP
Required Power Supply
350 W
Additional Requirements
CD-ROM
System Requirements Details
Pentium 4 RAM 256 MB - HDD 50 MB
Software Included
Drivers & Utilities
16.8 cm
11.1 cm
Limited warranty - 3 years
