NVIDIA Quadro K1200 - Incredible 3D application performance in a flexible form factor. Now included in the box, a full-height bracket lets this single-slot and low-profile board fit into any full-height (ATX) desktop, mid-tower, or desk side tower enclosure. Four mini-DisplayPort to DVI-D SL adapters are included to enable DVI or DisplayPort displays to be driven out of the box (four displays active simultaneously). The Quadro K1200 is the perfect choice for Manufacturing or Media & Entertainment professionals who are transitioning to 4K applications, workflows, and photorealistic HDR (High Dynamic Range) rendering enabled by NVIDIA Iray. 512 CUDA cores and 4 GB of GDDR5 GPU memory with fast bandwidth enables your customers to create large, complex 3D models, and an all-new display engine drives up to four displays natively with DisplayPort 1.2 support for true 4K resolutions like 3840 x 2160 at 60 Hz with 30-bit color. Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 100+ professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster. PNY provides unsurpassed service and commitment to its professional graphics customers offering: pre and post-sales support, dedicated Quadro Field Application engineers and direct tech support hot lines. In addition, PNY delivers a complete solution including the appropriate adapters, cables, brackets, software installation disc and documentation to ensure a quick and successful install.
- NVIDIA Quadro K1200 for DVI - graphics card - Quadro K1200 - 4 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- Memory
- 4 GB GDDR5
- CUDA Cores
- 512
- Memory Interface
- 128-bit
- Max Resolution
- 3840 x 2160
- Max Monitors Supported
- 4
- 4 x Mini DisplayPort , 4 x DisplayPort - with adapter , 4 x DVI-D (Single-Link) - with adapter
- API Supported
- OpenCL, DirectCompute, DirectX 12, OpenGL 4.5
- 16 cm x 6.86 cm
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Bus Type
- Graphics Engine
- CUDA Cores
- 512
- Max Resolution
- 3840 x 2160 at 60 Hz
- 4
- API Supported
- Nvidia SLI Multi-GPU Technology, NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Dolby True HD support, DTS-HD Master Audio support, Hardware Video Decode Acceleration, Shader Model 5.0, Dolby Digital Plus, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Nvidia Quadro Mosaic Technology, Bindless Textures, Nvidia Temporal Anti-Aliasing Technology (TXAA), ultra-quiet active fansink, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 128-bit
- Bandwidth
- 80 GBps
- OS Required
- SunSoft Solaris, Linux, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8 / 8.1
- Min RAM Size
- 2 GB
- Min Hard Drive Space
- 200 MB
- Additional Requirements
- DVD-ROM
- 45 Watt
- Included Accessories
- Full-height bracket
- Cables Included
- 4 x Mini DisplayPort-DisplayPort adapter , 4 x Mini DisplayPort-DVI adapter
- Software Included
- Drivers & Utilities
- 16 cm
- 6.86 cm
- ENERGY STAR Certified
- Limited warranty - 3 years
