The PNY NVIDIA GeForce GTX 1080 is a quantum leap in performance. Faster than both the GeForce GTX 980 Ti and GeForce GTX TITAN X, With the power of the NVIDIA Pascal architecture, the efficiency and performance of the 16nm FinFET GPU, the blistering speed of the GDDR5X VRAM, and the craftsmanship of the fan, vapor chamber, and backplate the PNY GTX 1080 is the world's fastest and most advanced graphics card.
The PNY GTX 1080 uses the power of Pascal. NVIDIA Pascal is the world’s most advanced GPU architecture delivering truly game-changing performance, innovative technologies, and immersive, next-gen VR. With brilliant gameplay with captivating sights and sounds, it’s a whole new way to game.It features NVIDIA GameWorks technologies for smooth gameplay and cinematic experiences, as well as revolutionary 360-degree image capture-even in VR.
Under the hood, the new Pascal architecture is loaded with technologies that will make your games and experiences better, faster, and more beautiful. Previous-generation architectures have brought advances such as DSR, G-SYNC and HairWorks to life, and with Pascal we're introducing gamers to Ansel, Simultaneous Multi-Projection, VRWorks Audio, VR PhysX, and VR Touch.
PNY’s GTX 1080 is a quantum leap forward in performance and power efficiency. It is built using ultra-fast FinFET, this new, smaller chip design uses fewer Watts of power and emits less heat, enabling us to crank up the core clock speed of the GPU, which is key for increasing a graphics card's performance. Alongside the FinFET is 8GB of GDDR5X memory, a new, faster type of video card memory. This cutting-edge and blazing fast, High Bandwidth memory ensures performance won’t be bottlenecked by memory-related operations in the most demanding games.
The PNY GeForce GTX 1080 is meticulously crafted to offer superior heat dissipation using an advanced vapor chamber and premium materials, so it runs as cool as it looks. Surrounding the GeForce GTX 1080's powerful hardware is a redesigned vapor chamber and fan for cool, quiet operation; a polygonal shroud, and a backplate for the dissipation of heat from the rear of the graphics card. This premium design enables excellent overclocking and whisper-quiet operation, a trend we began with previous-generation NVIDIA GeForce GTX GPUs.
HDMI 2.0b / 3x DisplayPort 1.4 / Dual-Link DVI
Amazing gaming platform
Driven by the NVIDIA Pascal architecture, the GeForce GTX 1080 delivers the amazing performance, advanced gaming technologies, and immersive VR. -
Excellent performance
The GeForce GTX 1080 is a quantum leap in performance and power efficiency. It's built using ultra-fast FinFET and high-bandwidth technologies, and supports DirectX 12 features for the fast, smooth, power-efficient gaming experiences. -
NVIDIA Pascal
GeForce GTX 1080 uses the power of Pascal to meet the demands of the displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks technologies for smooth gameplay and cinematic experiences, as well as 360-degree image capture - even in VR. -
VR ready
Discover VR performance, the low latency, and Plug and Play compatibility with headsets - driven by NVIDIA VRWorks technologies. VR audio, physics, and haptics let you hear and feel every moment. -
Outstanding design
The GeForce GTX 1080 is meticulously crafted to offer superior heat dissipation, using an advanced vapor chamber and premium materials, so it runs as cool as it looks.
- PNY GeForce GTX 1080 - Founders Edition - graphics card - GF GTX 1080 - 8 GB
- Dedicated Memory
- 8GB GDDR5X
- Memory Interface
- 256-BIT
- Memory Bandwith
- 320 GB / sec
- GPU Cores
- 2560
- Clocks
- 1 607 MHz Base/1 733 MHz Boost
- System Interface
- PCI Express 3.0
- TDP
- 180 W
- Thermal Solution
- Single Active Fan
- Display Connectors
- DVI, 3x DP, HDMI
- Resolution
- 7680 x 4320 @ 60 Hz
- Power Input
- 1 x PCIE 8-pin
- Supported SLI
- NVIDIA® SLI® w/ HB Bridge Support
- Sku
- GF1080GTX8GEPB
- EAN
- 3536403350765
- Incl. in the box
- GeForce Experience CD, Quick Start Guide, 2x6-pin to 1x8-pin PCIE adapter
- Dedicated Memory
- 8GB GDDR5X
- Memory Interface
- 256-BIT
- Memory Bandwith
- 320 GB / sec
- GPU Cores
- 2560
- Clocks
- System Interface
- PCI Express 3.0
- TDP
- 180 W
- Thermal Solution
- Single Active Fan
- DVI, 3x DP, HDMI
- Resolution
- Power Input
- 1 x PCIE 8-pin
- Supported SLI
- Sku
- GF1080GTX8GEPB
- EAN
- 3.5364E+12
- Incl. in the box
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
