PNY GeForce GTX 970 XLR8 OC 4GB GDDR5 1127MHz/1266MHz PCI-E
Quicklinx: BJGNWS00 Mfr#: KF970GTX4GEPB
  • NVIDIA GeForce GTX 970
The GeForce GTX 970 is a high-performance graphics card designed for serious gaming. Powered by NVIDIA Maxwell architecture, it features advanced technologies and class-leading graphics for incredible gaming experiences.
  • NVIDIA Maxwell
    This is NVIDIA's most advanced architecture ever, delivering incredible performance and unmatched power efficiency. Plus, it offers cutting-edge features like advanced sampling and Dynamic Super Resolution technology that delivers 4K-quality gaming - even on 1080p displays.
  • Multi-Frame sampled Anti-Aliasing (MFAA)
    MFAA delivers a 30% performance boost while maintaining smooth, high-quality edges by alternating sample calculations across each frame and each pixel.Learn more
  • Dynamic Super Resolution (DSR)
    This innovative feature can delivers 4K fidelity to 1080p displays for exceptional detail and image quality.
  • Voxel Global Illumination (VXGI)
    Part of the NVIDIA GameWorks library for developers, VXGI accelerates dynamic lighting effects for a truly immersive, cinematic experience.
  • GeForce Experience
    The easiest way to optimize your games and keep your drivers up to date, the GeForce Experience application automatically notifies you of driver releases from NVIDIA. With a single click, you'll be able to update the driver directly, without leaving your desktop. You can also capture and share 4K gameplay with NVIDIA ShadowPlay.
  • NVIDIA GameStream
    Stream extreme GeForce GTX PC gaming experiences to portable devices like NVIDIA SHIELD with super-smooth, low-latency performance.
  • NVIDIA G-SYNC
    This groundbreaking display technology delivers the smoothest and fastest gaming experience ever. G-SYNC's revolutionary performance is achieved by synchronizing display refresh rates to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. Scenes appear instantly, objects look sharper, and gameplay is super smooth, giving you a stunning visual experience and a serious competitive edge.
  • NVIDIA GPU Boost 2.0
    This innovative technology allows gamers to push PC performance to the maximum with precise controls. It intelligently monitors work with advanced controls like GPU temperature target, overclocking, and overvoltage to ensure that the GPU works at peak performance.
  • NVIDIA Adaptive VSync
    Nothing is more distracting than frame rate stuttering and screen tearing. The first tends to occur when frame rates are low, the second when frame rates are high. Adaptive VSync is a smarter way to render frames using NVIDIA Control Panel software. At high framerates, VSync is enabled to eliminate tearing. At low frame rates, it's disabled to minimize stuttering.
  • NVIDIA surround with up to four monitors
    Now, you can play your favorite games across four monitors. At 5760 x 1080, the expanded field of view fully engages peripheral vision and provides for the most immersive experience in racing and flight simulators.
  • NVIDIA SLI technology
    Used by the most demanding gamers worldwide, SLI technology lets you link up to four NVIDIA SLI-Ready cards together for astounding performance.
PNY XLR8 GeForce GTX 970 OC - XLR8 GAMING Edition - graphics card - GF GTX 970 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB GDDR5
Core Clock
1127 MHz
Boost Clock
1266 MHz
CUDA Cores
1664
Effective Memory Clock
7 GHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
DVI-I (dual link) , 2 x DisplayPort , HDMI
API Supported
OpenCL, OpenGL 4.4, DirectX 12
4.1 cm x 25.5 cm x 12.6 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1127 MHz
Boost Clock
1266 MHz
CUDA Cores
1664
Max Resolution
4096 x 2160
4
API Supported
Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA Project SHIELD Ready, Nvidia GeForce ShadowPlay, NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia Temporal Anti-Aliasing Technology (TXAA), NVIDIA GameWorks
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7 GHz
Bus Width
256-bit
Required Power Supply
600 W
Additional Requirements
2 x 6 pin PCI Express power connector
190 Watt
4.1 cm
25.5 cm
12.6 cm
Limited warranty - 3 years
BJGN C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
