The PL806 ADF document scanner, a member of Smart Office series, offers high-speed scanning capability and compact design, making it a perfect solution for workgroups and other decentralized scanning applications.
The PL806 ADF scanner provides a maximum scanning speed of 8 pages per minute, optical resolution up to 600 dpi, and permits identify of large quantities of documents at high speed by built-in Auto Document Feeder (ADF) that holds up to 50 pages.
Besides, it can be used as regular flatbed scanner easily, which adds ever more versatility to provide all your need. This PL806 ADF scanner is a truly versatile document scanner that puts up outstanding value and high performance, making it a perfect business and SOHO solution.
- Plustek PL806 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Light Source
- Xe-gas cold cathode fluorescent lamp
- Max Supported Document Size
- 220 x 355.6 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels)
- Optical Resolution
- 600 dpi
- Max Document Scan Speed
- 8 ppm (mono)
- Max Document Size
- 220 mm x 355.6 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- System Requirements
- Microsoft Windows XP Professional SP1, Microsoft Windows XP Home Edition SP1, Microsoft Windows 2000 SP4
- Microsoft Certification
- Certified for Windows Vista
- 4.8 kg
- Interface Type
- USB 2.0
- 220 x 355.6 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- 600 dpi
- CCD
- Bulb / Light Source Type
- Max Document Scan Speed B/W
- 8 ppm
- Scanner Speed Details
- 8 ppm - greyscale - A4 - 200 dpi
- TWAIN
Media Handling
- Max Document Size
- 220 mm x 355.6 mm
- Plain paper
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- UL, TUV GS, C-Tick, cUL, CB, FCC
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities, Presto! ImageFolio, Presto! PageManager 6.0, ABBYY FineReader 6.0 Sprint Plus
- OS Required
- Additional Requirements
- CD-ROM, USB port
- System Requirements Details
- Pentium III - 1 GHz - RAM 256 MB - HD 800 MB
- 4.8 kg
