Plustek OpticPro A320 takes the pain out of large format scanning. It is USB 2.0 scanning device that can scan an A3 size document with high quality - resolution as high as 1600 dpi and scanning area as large as 12" x 17" (304.8 mm x 431.8 mm) - in just 11.2 seconds. Often, large format scanning is considered to be complex but Plustek OpticPro A320 makes is very easy for the end-user with its seven one-touch function buttons. What's more, it comes bundled with highly effective image processing and document management software for enhanced versatility. It provides for fast and secure PDF conversion, highly accurate optical character recognition (OCR) and easy sharing of files over a network.
Plustek OpticPro A320 has been specially designed for professionals who require best of both worlds - high quality results coupled with efficiency. It is ideal for graphic designers, publishing companies, libraries, schools, small office/home office (SOHO) users and for those who require to do large format scanning regularly like hospitals, law firms, financial institutions etc.
- Plustek OpticPro A320 - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Light Source
- Xe-gas cold cathode fluorescent lamp
- Max Supported Document Size
- 304.8 x 431.8 mm
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 1600 dpi x 1600 dpi
- Scan Speed
- 11.2 sec / page
- Max Document Size
- 304.8 mm x 431.8 mm
- Document Feeder Type
- Manual
- System Requirements
- Microsoft Windows Vista / 2000 / XP
- Microsoft Certification
- Compatible with Windows 7
- 62.3 cm x 40 cm x 13 cm
- 7.5 kg
- Interface Type
- USB 2.0
- 304.8 x 431.8 mm
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- Scan Mode
- Single-pass
- CCD
- Bulb / Light Source Type
- Scan Speed
- 11.2 sec / page
- Control Panel Buttons Functions
- Scan, copy, email, file, PDF/OCR
- Scanner Speed Details
- 11.2 sec/scan - colour - A3 - 300 dpi , 11.2 sec/scan - greyscale - A3 - 300 dpi , 11.2 sec/scan - black & white - A3 - 300 dpi
- TWAIN
Media Handling
- Max Document Size
- Manual
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x USB cable
- C-Tick, BSMI, CB, FCC, C-ETL, ETL
- Power Device
- External power adapter
- Power Consumption Operational (Standby)
- 36 Watt (4 Watt)
- Software Included
- Drivers & Utilities, ABBYY FineReader 6.0 Sprint Plus, NewSoft MaxReader, Plustek DI Capture, Plustek DocAction, NewSoft Presto! ImageFolio 4.5, NewSoft Presto! PageManager 7.10
- OS Required
- Additional Requirements
- CD-ROM, graphics card, USB port
- System Requirements Details
- Pentium 4 - 2 GHz - RAM 512 MB - HD 800 MB
- 62.3 cm
- 40 cm
- 13 cm
- 7.5 kg
