Advanced Wireless Stereo Gaming Headset with long wear comfort to keep you in play
Get the most out of your Xbox 360 with the wireless Plantronics GameCom X95. Play games, listen to music and watch movies without disturbing others. Concealed mic-boom hides into the headband and out of your way. The headset adapter easily connects to your console for the ultimate wireless experience.
Experience wireless freedom for Xbox® gaming with the GameCom® X95™. A closed-ear design, with 40mm speakers, lets you enjoy a truly immersive gaming experience, music and movies in full stereo sound without disturbing others. The headset has separate chat and audio volume controls conveniently located on the earpods. The GameCom X95 has a sleek and modern design with a concealable mic that easily tucks into the headband when not in use. The specially designed earpods and headband mean you can stay comfortable even over marathon gaming sessions.
Superb Audio Experience Plus Comfort for Longer Sessions
- Enjoy immersive gaming, thanks to a closed-ear design and 40 mm speakers
- Tuck away the adjustable microphone when not in use
- Stay comfortable with the specially designed earpods and headband
- Adjust the volume using convenient on-ear controls
- Play in style thanks to the sleek, contemporary design
- Connect easily to your Xbox 360® and TV
- Poly - Plantronics GameCom X95 - headset
- Product Type
- Headset - wireless
- Recommended Use
- Game console
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Sound Output Mode
- Stereo
- Microphone
- Boom
- Controls
- Mute, volume
- 2-year warranty
- Designed For
- Xbox 360, Xbox 360 S
- Product Type
- Recommended Use
- Game console
Audio Output
- Full size
- Wireless
- Sound Output Mode
- Stereo
- Diaphragm
- 40 mm
Microphone
- Boom
Remote Control
- Controls
- Mute, volume
- Connector Type
- 3 x headset , USB (4 PIN USB Type A)
- Included Accessories
- Wireless adapter
- Cable Details
- 2 x headset cable , USB cable
- Limited warranty - 2 years
- Designed For
