Easily install large screens with this simple, intuitive mounting solution. It's simple three step installation combined with its tool-less tilt angle adjustment enables flat panel screens to be installed and adjusted quickly. Cables and cords are easily managed behind the screen with large access ports in the wall plate. For perfect screen positioning, center the screen by smoothly sliding it along the wall plates horizontal rails.
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
7JHL 045949 Condition: Damaged stock - Item is new but has packaging damage |
£7.94 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
