Peerless-AV SmartMount Universal Tilt Wall Mount for 32" to 50" Displays
Quicklinx: 7MV9WS00 Mfr#: ST640P
Type: Mounting kit
20 In Stock
£56.81 ex VAT
£68.17 inc VAT
Ideally suited for medium/large LCD screens, the SmartMount ST640P tilting mount allows you to mount your LCD screen quickly and easily. The tilt function allows you to angle the screen forward or back for an enhanced viewing angle.
Peerless SmartMount Universal Tilt Wall Mount ST640P mounting kit - for LCD display - black
Mounting kit - wall-mountable
Mounting Components
Bracket, tilt wall plate, security fasteners
56.2 cm x 47 cm x 14.5 cm
4.22 kg
Recommended Use
LCD display
Recommended Display Size
32"-50"
VESA Mounting Interface
400 x 400 mm
Max Mounting Pattern Size
458 x 449 mm
Max Load Weight
68 kg
5-year warranty
56.2 cm
47 cm
14.5 cm
4.22 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
400 x 400 mm
458 x 449 mm
32"-50"
Max Load Weight
68 kg
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
