Peerless-AV SmartMount Universal Flat Wall Mount for 10" to 29" Displays
Quicklinx: 7MTWWS00 Mfr#: SF630P
Type: Mounting kit
29 In Stock
£18.66 ex VAT
£22.39 inc VAT
Ideally suited for small LCD screens, the SmartMount SF630P flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 25mm away from the wall.
Peerless SmartMount Universal Flat Wall Mount SF630P mounting kit - for LCD display - black
Mounting kit
Mounting Components
Wall plate, mounting adapter
15.3 cm x 2.48 cm x 14.6 cm
0.8 kg
Recommended Use
LCD display
Recommended Display Size
10"-29"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
36.3 kg
5-year warranty
15.3 cm
2.48 cm
14.6 cm
0.8 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
10"-29"
Max Load Weight
36.3 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
