Peerless-AV Peerless  Portrait Locking Tilt Wall Mount For 32-58" Flat Panel Scre
Quicklinx: 7MXWWS00 Mfr#: PTLP650
£177.23 ex VAT
£212.67 inc VAT
Peerless-AV security lockable mounts offer the next level of security within the wall mount range with a secure locking bar and provided padlock.
Peerless Portrait Tilting Security Locking Mount PTLP650 - mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Tilt wall mount
50.8 cm x 6.6 cm x 71.5 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
32" - 58"
VESA Mounting Interface
700 x 400 mm
Max Load Weight
79 kg
50.8 cm
6.6 cm
71.5 cm
AV Furniture
Mounting kit
Mounting Components
Tilt wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
700 x 400 mm
32" - 58"
Adjustments
Tilt
Max Load Weight
79 kg
Lockable
Brand: Peerless-AV
