Peerless-AV Metal Shelf
Quicklinx: BX1YWS00 Mfr#: ACC-MS
Hurry, only 1 left in stock!
£76.13 ex VAT
£91.35 inc VAT
The SmartMount Metal Shelf is designed to attach to the newly redesigned SmartMount SR Flat Panel cart and SS Flat Panel stand. The shelf provides a secure yet sleek surface for various AV equipment and accessories to create great viewing experience.
Peerless-AV SmartMount ACC-MS mounting component - for AV System - black powder coat
Mounting component
Mounting Components
Shelf
50.8 cm x 41.6 cm x 8.7 cm
5.91 kg
Recommended Use
AV System
Max Load Weight
4.55 kg
Material
Metal
Black powder coat
5-year warranty
50.8 cm
41.6 cm
8.7 cm
5.91 kg
Material
Metal
Black powder coat
AV Furniture
Mounting component
Mounting Components
Shelf
Recommended Use
AV System
Max Load Weight
4.55 kg
Quick release, scratch-resistant
Dimensions & Weight Details
RoHS
Limited warranty - 5 years
Brand: Peerless-AV
