The Paramount series wall mounts provide versatile and multi-functional features. With PA750, extend the display up to 21.35" (542 mm) or fully-retract it to just 3.00" (76 mm) from the wall for the perfect viewing angle. The Hook-and-Hang system offers easy, one-person installation of the display. A ratcheting handle provides locking tilt capability for quick adjustments to the amount of tilt, reducing glare and optimizing the viewing angle. Integrated cable management protects, contains and conceals cables for a clean installation.
- Peerless-AV Paramount PA750 mounting kit - for flat panel - gloss black
- Product Type
- Mounting kit
- Mounting Components
- Articulating wall mount
- 61.9 cm x 7.6 cm x 42.5 cm
- Adjustable Depth
- 7.6-54.2 cm
- Tilt
- -5° to 15°
- Adjustments
- Roll, tilt, swivel
- Recommended Use
- Flat panel
- Recommended Display Size
- 39"-75"
- VESA Mounting Interface
- Up to 600 x 400 mm, from 200 x 100 mm
- Max Load Weight
- 45.4 kg
- Gloss black
- 5-year warranty
- 61.9 cm
- 7.6 cm
- 42.5 cm
- Adjustable Depth
- 7.6-54.2 cm
- Gloss black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Cable Management
- Integrated cable management
- 39"-75"
- Tilt
- -5° to 15°
- Adjustments
- Max Load Weight
- 45.4 kg
- Limited warranty - 5 years
