Parallels Desktop 8 for Mac Retail Box Corp EN
Quicklinx: 8B9TWS00 Mfr#: PDFM8L-BX1-EN
Parallels Desktop for Mac is the most tested trusted and talked-about solution for running Windows applications on your Mac - without rebooting.
With Parallels Desktop for Mac, you can seamlessly run both Windows and Mac OS X applications side-by-side without rebooting. Drag and drop files between Windows and Mac applications and launch Windows applications from your Mac dock. Powerful performance lets you run Windows productivity applications, even graphics intensive ones, with ease.
Whether you use an iMac, MacBook Pro or MacBook Air, Parallels is easy to set up. Simply download the software from, enter your key and you're up and running. Then you can enjoy any of the Windows programs you need - even Microsoft Office 2010, the gold standard of productivity software - right on your Mac.
  • Seamless solution
    Use Windows, side-by-side, with macOS on your MacBook, MacBook Pro, iMac, iMac Pro, Mac mini or Mac Pro - no restarting required. Share files and folders, copy and paste images and text, and drag and drop files and content between Mac and Windows applications.
  • Easy setup
    Parallels Desktop automatically detects what you need to get started so you can get up and running within minutes!
  • Lightning-fast
    Graphic and resource-hungry Windows applications run effortlessly without slowing down your Mac. Run applications such as Microsoft Office, Visual Studio, SQL Server, PowerBI, AutoCAD, MetaTrader, and thousands more. Play your favorite classic Windows-only games on a Mac.
  • Choose your view
    Make Windows invisible while still using its applications in Coherence mode, or if you're new to Mac, you can set Windows to occupy your entire screen, so it looks just like it would if you were using a Windows PC.
Parallels Desktop for Mac (v. 8) - box pack - 1 user
Box pack
Category
Utilities - desktop virtualisation
Version
8
Licence Qty
1 user
Platform
MacOS
Language
English
Category
Box pack
Version
8
Platform
MacOS
Language
English
Licencing
Licence Qty
1 user
Supported OS
Apple MacOS X 10.6.8 or later, Apple OS X 10.8 Mountain Lion, Apple MacOS X 10.7.4 or later
Hardware Requirements
Core 2 Duo RAM 2 GB - HD 700 MB
